Infamous Header Rattle
Old May 26, 2003 | 04:38 PM
PolyPill's Avatar
Default Infamous Header Rattle
I installed a DC Sports 4-1 header on my 2k1 Integra GSR and now I've got that damned header rattle around 3k rpms. VERY VERY annoying!
I thought it might be the heat shield by the cat, since that is the area it sounds like it is coming from, but unless the cat is moving a good 2 inches there's no way it's hitting that. There was no rattle with the stock header.
The clearance on the oil pan concerns me, it's about 2mm, seams like a very likely place to be hitting, but it doesn't sound like it is coming from there and if it were I would think it would be a very common problem. And I have no clue how that would be fixed.
Everything I read seams to be about older itrs with a stock header, it has been rattling since I put the thing on when it only had 20k miles. Any ideas? or should I just give the people at DC Sports a punch in the stomach?
Old May 26, 2003 | 05:15 PM
CNSK's Avatar
Default Re: Infamous Header Rattle (PolyPill)
mine rattles too from 3-500 rpm just in between those ranges, any lower or higher doesnt rattle. I think its my cat.....not for sure...
Old May 26, 2003 | 06:51 PM
NeoGSR's Avatar
you're old header didn't rattle??? wow!!! i wish mine was like that.....i know i have more than 2mm between the header and the oil pan so that may be where it's rattling....
Old May 26, 2003 | 06:57 PM
PolyPill's Avatar
Default Re: Infamous Header Rattle (NeoGSR)
That is what I was thinking, but how would I fix that? I can't exactly move the header so there is more space....... I'm thinking that punching DC Sports is sounding like the thing to do.....
I still have my old header, 20k miles on it, I will sell it to anyone that wants it, but I think shipping on an item that heavy would not make it worth while.
Old May 27, 2003 | 05:09 AM
PolyPill's Avatar
Bump, Really need some help on his issue
Old May 27, 2003 | 05:49 AM
98integrah's Avatar
I have the same problem! I installed my cat-back and when i reach around 4k rmps i hear this loud rattle right under the cd player area. When i had it stock it didnt make a sound but now that i have my cat-back on...its non-stop rattling. I would like to know wat it is and how to stop it too.
Old May 27, 2003 | 08:39 AM
TegLove's Avatar
Default Re: Infamous Header Rattle (98integrah)
check the sig same issue here......only sometimes when i first start my car is has this quiet irritated metal on metal grinding rubbing squeaking sound....anyone have this issue? and if so get rid of it?
Old May 27, 2003 | 08:48 AM
PolyPill's Avatar
Default Re: Infamous Header Rattle (TegLove)
So this seams to be a common issue, but no one has any solutions.
Old May 27, 2003 | 09:01 AM
tornactive.com's Avatar
I have the problem also..around 2700-3000RPM.
I have a DC 4-1
Old May 27, 2003 | 09:52 AM
TegLove's Avatar
Default Re: Infamous Header Rattle (tornactive.com)
I think that maybe we are just all idiots for getting the 4-1.....its a sign we shoulda gone 4-2-1..lol
Old May 27, 2003 | 10:11 AM
PolyPill's Avatar
I think this just means I have to get a turbo sooner than anticipated
Old May 27, 2003 | 10:20 AM
IntEGNYC's Avatar
The solution would be to Boost
Old May 27, 2003 | 10:57 AM
BeesDA6's Avatar
Default Re: Infamous Header Rattle (IntEGNYC)
I had the same problem with my wifes 97 after i installed the header. what i did was I kinda tweaked the bracket. (the one that is bloted to the block that holds the downpipe) There are 2 bolts that hold the bracket to the block. i only used one, the top bolt. The bottom hole should be shifted away from the bolt hole towards the right if i can remember. at first I didnt think it would work cause its only one bolt holding the top, but it did. Hth
Old May 28, 2003 | 06:56 AM
arsenaldragster's Avatar
Default Re: Infamous Header Rattle (BeesDA6)
Did everyone use their gaskets?? It still might be the heat shield.. As for the persons that was squeaking during start up, did you install an aftermarket exhaust?? Sometimes the shifter will hit the pipe (if larger aftermarket) and will squeak at start up. Hope this can help someone!
Old May 28, 2003 | 07:14 AM
97CivicLS's Avatar
u used one bolt.....did you get an exhaust leak?
Old May 28, 2003 | 11:45 AM
IntEGNYC's Avatar
Default Re: Infamous Header Rattle (97CivicLS)
The idea of upgrading the headers is now sounding very dodgy... BUmp for a good thread.
Old May 29, 2003 | 08:24 AM
BeesDA6's Avatar
no leak. this bracket is bolted from the block to the downpipe. The bolt that you will remove is the bolt on the block side.
Old May 29, 2003 | 12:23 PM
97CivicLS's Avatar
oh ok, sweet. whatever works man......kick ***
Old May 31, 2003 | 06:36 AM
IntegGirlRacer's Avatar
i have this problem too and its soooo annoying and soo embarassing! It started right after I installed my 4-2-1 DC Sports header. I have an APEXi N1 exhaust with it. The rattle is usually around 1,600 rpms. It is quite loud, and i have it at start up as well. The dealer and everyone who has looked and heard it said htey think its the heat shields, but i am soo fed up with it. Any fixes???
Old Dec 1, 2004 | 07:24 AM
kseriesDC5's Avatar
Default Re: (IntegGirlRacer)
im from the rsx / ep3 forums, and i now have this same problem, the thing is i dont have a cat to rattle ;x what can it be??
Old Dec 1, 2004 | 07:45 AM
LSvtec03's Avatar
Default Re: (kseriesDC5)
probably heat shield rattles. take em off.
Old Dec 1, 2004 | 07:49 AM
S1ERRA's Avatar
Default Re: (LSvtec03)
i had the same problem... i ignored it and it eventually went away... maybe i got lucky...
::bookmarking this thread in case it comes back::
Old Dec 1, 2004 | 09:49 AM
MugenGSR2001's Avatar
Default Re: (-sierra-)
I may not be an expert on this subject, but perhaps what Ive read and heard may help. If not...just ignore, I guess...
Ive heard that the DC Sports headers have fitting issues when it comes to the installs and that the problem involves them hitting the heat shields (I know, pretty much going along with what everyone else has said...). With your header being a DC Sports, perhaps everyone is correct in saying its the heat shield, plus with the rep of DC Sports headers not fitting well...perhaps that IS your problem...who knows though...
Old Dec 1, 2004 | 10:02 AM
teggy2154's Avatar
Well i just bought a 96' integra RS and its been doing well until today. Right before hitting 109,000 miles on the odometer, it jus stopped even the trip miles. Another thing, as i come to a complete stop, a hear a whooshing sound that may be involved with my tires cuz every time they make a full rotation as i am nearing a complete stop i hear a sound. Please can you guys tell me wuts wrong?
Old Dec 1, 2004 | 11:44 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: (teggy2154)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy2154 &raquo;</TD></TR><TR><TD CLASS="quote">Another thing, as i come to a complete stop, a hear a whooshing sound that may be involved with my tires cuz every time they make a full rotation as i am nearing a complete stop i hear a sound.</TD></TR></TABLE>
Maybe you have one of those hidden $69.95 electric superchargers under your hood
As far as the rattling, if you have a stock header, the culprit is usually the B-pipe. The next best thing to check are the heat shields. If you have an aftermarket header then you should definitely check out your heat shields, especially the one on the CAT.
I had the same annoying rattling sound around similar stated RPMs...its gone now. It's been replaced by a WhiRrrRRing, whistling noise that goes PFfFFFsSsSsSH.
