Ignition Trouble
Old Feb 17, 2006 | 09:08 PM
Cabby89's Avatar
Default Ignition Trouble
Ok having a problem with the new DA. When I go to turn hte car off and pull the key out. Car turns off but I cant turn it all the way left to the off position and pull it out. It takes a lot of playing with it to finally get it off. So prolly have to change out the ignition switch??
Whats involved in removing the ignition and where can I get one for a good price.
Old Feb 17, 2006 | 09:12 PM
Tizight's Avatar
Default Re: Ignition Trouble (Cabby89)
I have a 95' and I have had that problem a few times. I say don't worry about it unless it turns into a constant thing. It only happens to me like once every month. Just fiddle with it.
Old Feb 17, 2006 | 09:15 PM
Cabby89's Avatar
Default Re: Ignition Trouble (Tizight)
Its a constant thing. Happened twice to me yesterday. The only 2 times I moved the car. Its my sisters car and Im getting bitched at cause shes been trying for 20min to get it out.
Old Feb 17, 2006 | 09:20 PM
tallyturbo's Avatar
id tell her to stfu...j/k. i had the prob a while back but it just stopped doing it so i never fixed it. good luck though
Old Feb 20, 2006 | 08:49 AM
Cabby89's Avatar
Anyone else had this problem? How'd you fix it?
Old Feb 20, 2006 | 09:49 AM
Lauj87's Avatar
ive changed out the ignition for my old honda accord..im pretty sure there all the same. but once you get the houseing off the steering wheel you'll see the dead bolt that holds the ignition switch in. your going to have to get a hammer and a punch to get it out. inorder to do this you have to slowly, i mean slowly turn the dead bolt by punching it out. there should be two bolts. and you can get a used igniton switch with key for about 150 bucks at the junk yard.
Old Feb 23, 2006 | 08:30 PM
Cabby89's Avatar
Default Re: (Lauj87)
How do I get that lower dash off?? I got the screws all off and cant get it pulled off. Seems like some clips are still holding it.
Old Feb 23, 2006 | 08:45 PM
BlUeDC2nEr's Avatar
Default Re: (Cabby89)
sounds like you need a new key cylinder.
i'd say parts and getting it recoded would cost about $70-$130 from the dealer.
good luck with it!
Old Feb 23, 2006 | 09:22 PM
Lauj87's Avatar
it might be the steering wheel lock holding it in..just wiggle it around alittle and try to shake it loose...take a picture of it if you can so i can see where your at..i did this a while back...don't really remember anymore.
S33
Nov 17, 2014 11:43 AM
exz0n-.-
Oct 23, 2008 04:57 PM
Arethereanynamesleft
Feb 27, 2007 08:23 PM
b20acura
Nov 5, 2006 09:36 PM
