ignition coil...
Old Apr 5, 2004 | 10:07 PM
CM-R's Avatar
Default ignition coil...
Will a 95 ls internal ignition coil work for my 00 gsr?
Old Apr 5, 2004 | 10:36 PM
JPineda's Avatar
Default Re: ignition coil... (CM-R)
Maybe!?! Why don't you just use the one for your GSR? If you need one, let me know. I have an internal coil for a 2000 GSR that I'm not using.
Old Apr 5, 2004 | 11:11 PM
CM-R's Avatar
Default Re: ignition coil... (JPineda)
pmed you
Old Apr 6, 2004 | 12:15 AM
AzntaggeR's Avatar
TSPeed Factory
i believe it should. if you look at it they're all basically the sameas we as the ignition control module. i used an ignition coil from a d15b7 dizzy to rebuild my gsr dizzy.
madhatter2199
Jul 12, 2005 08:29 PM
hondaeg8
Dec 21, 2004 11:46 PM
integrasi
Mar 5, 2003 12:28 AM
b18c1_powered_si
Sep 10, 2002 06:41 AM
