idle problem help! 93 DA
Old Sep 25, 2006 | 02:51 PM
Ilove theDA's Avatar
Default idle problem help! 93 DA
i have an 93 DA LS and my idle is bobbing as if i had a vacume leak. The idle is down to 1000rpm then its raises to about 2500. Wityh my exuast system this is getting old fast lol. I have done the following to try to fix this annoying problem.
.vacume leak test.....(no leak)
.ran all the air bubbles out off my coolant. (still idles funny)
.diagnostic check came up as o2 sensor. ( fixed that and still idles funny)
I am thinkin my throttle body or manifold is dirty thus ruining my IAC
(idle air censor) which i have purchases a new b16 manifold to put on and hope that when i clean my censor it will fix this problem. IF its not my IAC what do you guys see this problem being caused by????????? Thx for any opinions.
Old Sep 25, 2006 | 03:06 PM
lilpastrana's Avatar
Default Re: idle problem help! 93 DA (Ilove theDA)
Your map sensor possibley. Or your tps unlikely tho.
Old Sep 25, 2006 | 03:16 PM
map sensor??? tps?????
Old Sep 25, 2006 | 05:11 PM
bump
Old Sep 25, 2006 | 05:17 PM
vtec all day's Avatar
the knock senor is the problem cause i had the same problem on my DA
LopEz VTEC ALL DAY
Old Sep 25, 2006 | 05:38 PM
92integraVTECgsr's Avatar
Default Re: idle problem help! 93 DA (vtec all day)
the knock sensor has nothing to do with idle.
check all your hoses. check the hose from the brake booster to the intake manifold.
are you throwing and codes? is your check engine light on?
if its not on, check all the hoses again. maybe try cleaning the throttle body plate.
Old Sep 26, 2006 | 06:27 AM
I have checked all hoses and even ran a vacume leak test...im fine with vacume but my light is on and its code # 12 ima go look on batauto.com to see what that is. but like i said what else could this be if its not my IAC
that knock sensor comment was too funny. *props*
Old Sep 26, 2006 | 07:11 AM
Default Re: (Ilove theDA)
cell 12 is your EGR (exhaust gas reciculation lift valve)
Old Sep 27, 2006 | 07:02 AM
ok i did the ol fashion tie my diagnostic plug...the engine code it gave me was.....iono :] my engine light blinked one long time and 2 small times so is that 12, 2 or what??? and even when i pull the coldes for those two it comes up a vtec cylenoid and o2 snesor. fist of all im a LS and 2nd of all i just replaced my o2 sensor like a week ago. HELP me my integra brothas.
Old Sep 27, 2006 | 07:04 AM
Rajin's Avatar
MAP Sensor more than likely.
Old Sep 27, 2006 | 08:07 AM
ok map sensor any others? thx for all the help so far guys. Can anyone tell me for sure what code my car is givin me when it blinks on long time and 2 short ones?
Old Sep 27, 2006 | 08:09 AM
When I say "it blinks" i am talking about my check engine light. just to be clear :]
Old Sep 27, 2006 | 09:48 AM
bump
Old Sep 28, 2006 | 06:06 AM
bump any answers...last bump :/
Old Sep 28, 2006 | 06:33 AM
GRIFTERX's Avatar
what is the knock sensor's purpose??? when i had my b16 rex i was also idling funny, then i checked the cel codes and it was throwing o2 censor, but when i replaced them, i found that the cel codes were throwing knock censor and that was where i got ownd.
Old Sep 28, 2006 | 07:51 AM
Rhythmsnewsn's Avatar
Default Re: idle problem help! 93 DA (GRIFTERX)
one long flash and 2 short = code #12 i would tell you what it means but the search function isnt working properly
Old Sep 28, 2006 | 10:07 AM
92db2's Avatar
well if your saying you have an LS then the b16 manifold is gonna do nothing for you. since you can't use it. it's not gonna bolt up to your head. second the IACV is idle air control valve and i would bet if you either replaced just this or took it off and cleaned it really good it would fix your problem. i am not sure if your car has it or not but the fast idle valve could be a problem also.
later
casey
dc4b20
Nov 21, 2012 05:58 AM
djviet2000
Aug 20, 2008 08:19 PM
TMC_EF
Mar 8, 2007 05:40 PM
boostin1cam
Jul 20, 2005 05:39 PM
CA6VTEC
Sep 14, 2004 05:57 PM
