Identify This Swap?
Old Sep 29, 2010 | 06:31 AM
iM x Omar's Avatar
Icon2 Identify This Swap?
What kind of swap is this anyone know? by looking at it?
what type of a cover is that?
Old Sep 29, 2010 | 06:41 AM
lazlong's Avatar
Default Re: Identify This Swap?
It's a DOHC. Looks like a b18. Only way to know for sure is to look on the block and post what it's stamped with.
Old Sep 29, 2010 | 06:44 AM
kaiba's Avatar
Look like a OBD1 Integra LS.
Old Sep 29, 2010 | 07:12 AM
EpHatchy's Avatar
LS with maybe a moroso valve cover painted red...
Old Sep 29, 2010 | 08:07 AM
mrchevez's Avatar
Yeah forsure its a Moroso b18a/b valve cover that came in red or painted red. You could find them on ebay
Old Sep 29, 2010 | 08:19 AM
Hello Bart's Avatar
def. an LS engine... doesnt look like a moroso valve cover.. just looks like a stock one with the humps shaved off... and painted...
Old Sep 29, 2010 | 08:53 AM
90efb16's Avatar
def a 94 to 97 integra ls with the stock b18b1 motor with a shaved valve cover or aftermarket one.
Old Sep 29, 2010 | 10:46 AM
iM x Omar's Avatar
well i looked and its kinda dirty there but i wiped it off a bit and it says like b18c5 or b18c6 or something?
this is the closest ocover i found could this be the one
http://cgi.ebay.com/ebaymotors/OBX-J...Q5fAccessories
Old Sep 29, 2010 | 11:12 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Well everyone above is right, another dead giveaway is that there is NO vtec solenoid.
Old Sep 29, 2010 | 11:20 AM
iM x Omar's Avatar
right so its prolly just an LS swap like everyone is saying above, i just thought it looked different cuz of the cover.. i found it on ebay the cover its not a moroso. its called OBX Valve Cover $85 New Red
Old Sep 29, 2010 | 11:24 AM
singlecamslamed's Avatar
Stage 3 CLINGER!
Idk if I like it or not. Lol. Maybe if it had the Honda emblems..
Old Sep 29, 2010 | 11:47 AM
tougetuned_ef's Avatar
the someone either put an ls head on a b18c block or they took the vtec selenoid and is running no vtec. its hard to believe tht it says b18c anything!
Old Sep 29, 2010 | 11:57 AM
nels00n's Avatar
thats a 98-01 b18b1 (has sensor ontop of intake mani.) w either a moroso valve cover or some sort of ebay valve cover.
Old Sep 29, 2010 | 12:34 PM
jdmer329's Avatar
no one guessed it culd be a b20 u never kno with out looking at it in person or a pic of the stamp on the block. but it is a B series DOHC non-vtec
Old Sep 29, 2010 | 12:38 PM
nels00n's Avatar
TRUE^^^ LOL i didn't think of that lol
Old Sep 29, 2010 | 12:58 PM
90efb16's Avatar
unless some one but a ls head on a b20 bc b20 have a intake manifold that is higher then the valve cover or if its a 99 to 01 b20 it has that stupid plastic chamber thing on top of the manifold
Old Sep 29, 2010 | 01:06 PM
jdmer329's Avatar
ive seen it before...
Old Sep 29, 2010 | 01:52 PM
nels00n's Avatar
or they just swapped out the intake mani. you don't have to swap out the whole head.
Old Sep 29, 2010 | 02:07 PM
JdmTypeRdc2's Avatar
it can be either a b18a from a 90-93 Integra LS, or a b18b from a 94-97 Integra LS.
It can also be a b20. They offered 2 versions of the b20b, one high compression and one low compression, one being 8.8:1 and the other 9.6:1
The intake manifold could be swapped out, but it wouldnt make sense to do that...unless it was to clear the hood.
Best bet is a b18a or b18b1 from early model integras.
Old Sep 29, 2010 | 05:29 PM
fcm's Avatar
fcm
Old Fart
Pretty sure it is a G2 or G3 1.8L LS engine.
It is not a Moroso valve cover, it could be, as mentioned, a stock valve cover that has been "shaved" although I am pretty sure you can not shave that much off, more likely, also as mentioned, an eBay valve cover.
Look at the stamping, I can almost see it in the pic, it is at the left front end of the block directly below, [4-5 inches] the left end of valve cover, [distributor end]. 94
Old Sep 29, 2010 | 06:41 PM
red96turbols's Avatar
Your upper rad hose is kinked because its too long. Who ever installed it shouldn't even do an oil change. I'd check that thing out and see what else is improperly installed. or is it just sucked in because there is no coolant... lol. but yeah, I agree, looks like a LS of some sort. I doubt thats a C series block.
Old Sep 29, 2010 | 06:42 PM
SIREK4REP's Avatar
ls
Old Sep 29, 2010 | 06:57 PM
JDM Like Whoa's Avatar
Hmm, I think it could be a B series
Old Sep 29, 2010 | 07:17 PM
fernando.'s Avatar
I think your engine bay is crooked.
Old Sep 29, 2010 | 07:41 PM
Might want to get a tie down for that battery too... looks like its taking a bit of a tumble in there. and yeah EJ1-Fernando, looks like the rad support is closer on the pass. side than driver side huh.
