i need help fast
I believe you can manually close your sunroof. If you look at the ceiling inside your car you should see some plastic circles. When you remove the plastic circle rear passenger area you should see a hole. Using the tool that comes with the car you should be able to close your sunroof.
b16-ef-si
Oct 15, 2008 11:01 PM
