HyTech: Worth it?
Old May 27, 2003 | 09:33 AM
sknot1454's Avatar
Default HyTech: Worth it?
So, I'm looking to ditch my hyper medallion/dc 4-2-1 header for a better flowing combp(tanabe has 2 bottlenecks)
2100 for the entire set up.....header, muffler, b pipe, cat, etc etc
somewhere alone the lines of 20whp untunes
is this worth it...or should I spend the money to upgrade my valvetrain to make more power through higher rpms
anyone know a dealer I can buy from instead of going directly to the web site?
Old May 27, 2003 | 09:35 AM
acatak's Avatar
Default Re: HyTech: Worth it? (sknot1454)
I would spend the 2100 for other parts... just my $.02
Old May 27, 2003 | 09:41 AM
sknot1454's Avatar
Default Re: HyTech: Worth it? (acatak)
off topic but, what kind of difference did you notice after you installed your ITR cams? worth the $$$?
Old May 27, 2003 | 09:42 AM
acuraholic's Avatar
Just remove the bottlenecks from your Tanabe and buy a new header/cat. Spend the rest on something else.
Old May 27, 2003 | 09:44 AM
sknot1454's Avatar
Default Re: HyTech: Worth it? (acuraholic)
If I get a new header I'll probably go with a jdm ITR or a JDM DC 4-1
Old May 27, 2003 | 09:50 AM
P1mpSlap's Avatar
Yes it's worth it.
HyTech header makes about 10hp more over the JDM DC 4-1.
Old May 27, 2003 | 09:56 AM
neo1z's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">Yes it's worth it.
Id like to see a dyno plot of that.
Old May 27, 2003 | 10:24 AM
P1mpSlap's Avatar
Default Re: (neo1z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">
Id like to see a dyno plot of that.</TD></TR></TABLE>
PM VtecVoodoo he might have one. He's used both and now rocks a Comptech Race header. He'll vouche for the HyTech design.
You get what you pay for. HyTech is simply one of the best. the JDM DC doesn't come close to touching it.
Old May 27, 2003 | 10:33 AM
sknot1454's Avatar
Default Re: (neo1z)
Old May 27, 2003 | 10:40 AM
10K2HVN's Avatar
http://www.HyTechExhaust.com
..id say it Will be worth it if you want Maximum Power out of you car. If you just plan on ITR cams then i dont think so..but if your gonna get Jun3/4's or something equivalent then Yes.
Modified by 10K2HVN at 1:42 PM 5/27/2003
Old May 27, 2003 | 12:45 PM
MugenGTR's Avatar
Default Re: HyTech: Worth it? (10K2HVN)
i'd also recommend smsp! good shiet!
Old May 27, 2003 | 03:34 PM
AWDxBOOST's Avatar
Default Re: HyTech: Worth it? (MugenGTR)
sounds good to me....jus sit on it a while to see if thats what u really want
P1mpSlap's Avatar
my god
That motor is getting near 100% effiency w/ just tuning and that exhaust setup.
It just dominated that DC Header. Look at that ****. No comparrision.
Old May 27, 2003 | 04:03 PM
Austin's Avatar
Default Re: (neo1z)
Already done that...just lost it it all when photopoint went down...I need to find the original print outs that I did ~2 years ago.
Old May 27, 2003 | 04:07 PM
Austin's Avatar
Here is the link to the test that I did last August https://honda-tech.com/zerothread?id=269935 and here is the untuned dyno:
Car facts -
Comptech icebox and intake
Mugen headgasket(no correction to cam gears, roughly at -1.5, -1.5)
Hondata intake manifold gasket, street setup
Run#33 - Testing was done as delivered...just hoping on the dyno and seeing what the car put out.
Run#35 - Just bolted on the HyTech header and HyTech exhaust, test pipe was used.
full version, cut and paste:
http://www.imagestation.com/pi...g.jpg
For the rest including a semi tuned version please follow the link above.
Austin
Old May 27, 2003 | 04:13 PM
2lowintegra's Avatar
Default Re: (Austin)
for 2100 (plus a bit for your old header) you could do a half decent turbo setup... and make a shitload more than 20hp
Old May 27, 2003 | 04:23 PM
P1mpSlap's Avatar
Default Re: (2lowintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lowintegra &raquo;</TD></TR><TR><TD CLASS="quote">for 2100 (plus a bit for your old header) you could do a half decent turbo setup... and make a shitload more than 20hp</TD></TR></TABLE>
So could every ricer in the world. The point is this is one of the best exhaust systems you can buy, regardless of how much it costs.
Old May 27, 2003 | 04:28 PM
sak's Avatar
sak
Exactly. And If you wanted a Turbo setup, Hytech makes an exhaust for them too. It'll make more power than any turbo setup, just like this NA header makes hella power over any regular NA header.
Old May 27, 2003 | 04:46 PM
StinkyTofu's Avatar
Default Re: (sak)
How long is the wait for a hytech header? Its also not fair to compare that header to the dc jdm header as you can see the whole exhaust system changed, not just the header. Although those are very impressive gains. 2100 is so damn pricey though. They were right when people said "n/a ain't cheap".
Old May 27, 2003 | 04:59 PM
neo1z's Avatar
Default Re: (StinkyTofu)
I stand corrected
Old May 27, 2003 | 05:23 PM
sak's Avatar
sak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">How long is the wait for a hytech header? Its also not fair to compare that header to the dc jdm header as you can see the whole exhaust system changed, not just the header. Although those are very impressive gains. 2100 is so damn pricey though. They were right when people said "n/a ain't cheap".</TD></TR></TABLE>
The thing is custom made to your application, hence the wait for it.
And what changed about the exhaust system? The point is the Hytech is far more supperior to any mass produced exhaust system.
Old May 27, 2003 | 05:29 PM
Havokmkr's Avatar
Default Re: (sak)
Get a design plot for the hytech exhaust system and have some muffler shop make you a custom knock-off. Same as hytech only much cheaper. Talk to some people who know they're sh*t. If you want to really get the most out of your exhaust talk to surferx or MichaelDelaney on http://www.team-integra.net.
Old May 27, 2003 | 06:00 PM
Al Bundy's Avatar
Default Re: (Havokmkr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Havokmkr &raquo;</TD></TR><TR><TD CLASS="quote">Get a design plot for the hytech exhaust system and have some muffler shop make you a custom knock-off. Same as hytech only much cheaper. Talk to some people who know they're sh*t. If you want to really get the most out of your exhaust talk to surferx or MichaelDelaney on http://www.team-integra.net.</TD></TR></TABLE>
Naw its okay Imma still get a hytech
Old May 27, 2003 | 06:12 PM
acatak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sknot1454 &raquo;</TD></TR><TR><TD CLASS="quote">off topic but, what kind of difference did you notice after you installed your ITR cams? worth the $$$?</TD></TR></TABLE>def worth the money.... skunk 2 stage 1's work well too
Old May 27, 2003 | 06:26 PM
P1mpSlap's Avatar
I doubt HyTech will just give up their designs to just anyone.
