hydro lock
Old Feb 24, 2006 | 09:50 AM
b20integrapower's Avatar
Default hydro lock
i just wanted to know how water makes rods bend or go through the oil pan...wouldnt it be just like burning coolant? i dont get the physics of it..can anyone explain?
Old Feb 24, 2006 | 09:56 AM
bks84's Avatar
Loved
did you bother searching the itnernet on hydrolock?
essentially what happens:
water goes into teh combustion chamber.
the piston comes up on the compression stroke and tries to compress the water. well, as we all know, water doesnt take kindly to compression, so it bends the rods nad ***** some **** up.
does that help.
holy crap 1 second on google.
http://www.prepsparkplugs.com/hydrofact.htm
Old Feb 24, 2006 | 09:58 AM
kulrevon's Avatar
Default Re: hydro lock (b20integrapower)
well if you are burning coolant your headgasket would have to be blown. which means the cylinder won't hold much pressure. So when you actually get water in there it will just squeeze out (when you have bubbles in your radiator)or go out the exhaust.
The reason you can hydro lock a motor is because water is an incompressible liquid. You can't make water fit into a smaller space with more pressure like air.
so When you get a bunch of water in a cylinder and you have a good seal (headgasket) the piston will try to force its way up and compress the water. A few things can happen. (bent valves, broken piston, broken/bent rods, blow headgasket/ blow the head off.
hope this answers everything
Old Feb 24, 2006 | 05:38 PM
Default Re: (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">did you bother searching the itnernet on hydrolock?
does that help.
http://www.prepsparkplugs.com/hydrofact.htm</TD></TR></TABLE>holy crap! i dont care! and to the other guy...thank you very much! im here to learn and u definately helped out
Old Feb 24, 2006 | 05:52 PM
yee SERIOUS's Avatar
try burning water
the_tensl
Aug 13, 2014 11:09 PM
hondmywrld
May 9, 2007 12:35 AM
Hyaboosta
Jul 21, 2006 05:01 AM
Speed 101
Jan 28, 2006 06:44 PM
model x
Jul 23, 2004 04:09 PM
