how to remove OEM deck?
Old Mar 17, 2007 | 10:58 PM
20ls01's Avatar
Default how to remove OEM deck?
going buy a new deck, just want to know how to remove old one
heres a picture for you guys to show me how to remove
thanks..
Old Mar 17, 2007 | 11:03 PM
User 42624's Avatar
Default Re: how to remove OEM deck? (20ls01)
Old Mar 17, 2007 | 11:09 PM
calxtreme's Avatar
You have to get behind the deck where there are 1 or 2 bolts that old the deck back. after the bolt is off, you can slide the deck forward.
Old Mar 17, 2007 | 11:19 PM
GoldCoin's Avatar
take a flathead to the side and pry it out
Old Mar 18, 2007 | 04:27 AM
siksdb8's Avatar
Default Re: how to remove OEM deck? (DC TWOin IT)
wow... remove your shift ***, unscrew the center console, unscrew the ashtray and unplug it. now you should have access to unbolt the radio from the bottom, disconnect your harness and antenna and have a nice day
Old Mar 18, 2007 | 05:12 AM
mrdeadman's Avatar
They let me pick
http://www.team-integra.net/se...D=115
Old Mar 18, 2007 | 11:15 AM
IntegraDOHCter's Avatar
wtf why did you superglue your shift ****!??
Old Mar 18, 2007 | 12:11 PM
eidk's Avatar
Default Re: (20ls01)
okay... here is a way to get your deck out in under 5 minutes.....
take it to the ghetto... as you leave your car say out loud.. damnit i think i forgot to lock it but i will be back in 5 minutes... then poof.. you get back.. and you are ready for a new deck
Old Mar 18, 2007 | 12:26 PM
b20acura's Avatar
Default Re: (eidk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eidk &raquo;</TD></TR><TR><TD CLASS="quote">okay... here is a way to get your deck out in under 5 minutes.....
take it to the ghetto... as you leave your car say out loud.. damnit i think i forgot to lock it but i will be back in 5 minutes... then poof.. you get back.. and you are ready for a new deck</TD></TR></TABLE>
hahaha good one. have you tried it? are you willing to do it yourself?
Old Mar 18, 2007 | 12:42 PM
Blahblah718293's Avatar
Default Re: (b20acura)
hmm.. i think your whole car would propably be gone.
Old Mar 18, 2007 | 06:22 PM
phayzeone's Avatar
dude. read the team-integra article on G3 Head Unit Install. It is so easy....just get in your car and start unscrewing.
NM YOU PUT SUPER GLUE ON YOUR SHIFT ****. WTFFFFF...
Old Mar 18, 2007 | 10:51 PM
98GSRDC2's Avatar
use the search bar for your own sake. and go on teamintegra they got a good step by step. stop wasting our time and search before you post
Old Mar 18, 2007 | 10:53 PM
redGSRguy's Avatar
Default Re: how to remove OEM deck? (98GSRDC2)
Even if there is super glue on it you should be able to turn it and break the bond.
Old Mar 18, 2007 | 11:03 PM
deadline's Avatar
i'll buy that oem c/d player.............
Old Mar 19, 2007 | 01:09 PM
20ls01's Avatar
Default Re: how to remove OEM deck? (redGSRguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">Even if there is super glue on it you should be able to turn it and break the bond.</TD></TR></TABLE>
i used a lot....im kinda scared, ifi use too much strength, will it bend the shift linkage?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GSRDC2 &raquo;</TD></TR><TR><TD CLASS="quote">use the search bar for your own sake. and go on teamintegra they got a good step by step. stop wasting our time and search before you post</TD></TR></TABLE>
why you gotto be like that? thats not a cool way to treat another san francisco resident
Old Mar 19, 2007 | 01:22 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
No need to remove the console. Just remove the ash tray/lighter/cup holder assembly, and then you can access the screws behind the headunit holding it in place. You may have to situate yourself upside down in the passenger side foot well in order to see the screws.
I swear, too many @$$ holes up in here.
Old Mar 19, 2007 | 04:54 PM
20ls01's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">No need to remove the console. Just remove the ash tray/lighter/cup holder assembly, and then you can access the screws behind the headunit holding it in place. You may have to situate yourself upside down in the passenger side foot well in order to see the screws.
I swear, too many @$$ holes up in here. </TD></TR></TABLE>
but how do i access the ashtray screws and stuff without removing the center console?
bahhah ignore that question..didnt know the ash tray came off without screws only owned the car for a month
Old Mar 19, 2007 | 05:56 PM
-Kirk-'s Avatar
Use teflon tape on the shifter threads if it doesn't line up right. That's always worked for me. Surely that superglue will break pretty easy.
Old Mar 19, 2007 | 08:52 PM
99Geeezer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">how do i remove the deck without removing the center console?</TD></TR></TABLE>
You can't!!!
Old Mar 20, 2007 | 10:14 AM
bseries_ben's Avatar
Default Re: (99Geeezer)
honestly, it's not that hard. if you can't look around your dash for a few minutes and figure this out, you should probably go buy a focus or something. but if you don't want to try to figure it out for yourself, undo the ashtray assembly and find the 2 screws and undo them then slide the whole deal out towards you. pretty simple
Leg3nd
Feb 21, 2009 05:52 PM
uses0ap
Audio / Security / Video
Jan 22, 2009 06:00 AM
friscorice88
Dec 13, 2005 08:40 PM
dtrtw
Jun 30, 2005 02:50 AM
tremor86
Dec 1, 2002 05:29 AM
