How to remove injector
Yes I know its an easy thing but I dont have time right now to tinker with the stupid search...
What I really want to do is swap injectors from one cylinder to another to see if the misfire I am having changes cylinders.
Dont I have to relieve fuel pressure?
Do I just loosen that bolt on the fpr? Anything else involved?
You have to unbolt the fuel rail im not sure if there are two or three bolts. BE CAREFUL when pulling the injectors out. The o-rings are very delicate if they are old. Also there is little filters inside the injectors make sure those are in right when you put them back in.
This is all you get, since you asked so nicely.
Go to the parts store and get o-ring kits for each one. You'll trash 'em being that old.
Book says to crack the fuel filter bolts to relieve the pressure. I remove the fuel pump fuse and crank the engine a few times. No big deal.
e jay one
Mar 26, 2007 03:58 PM
B16Jacques
Jun 15, 2005 08:25 PM
