how to: help with stripped bolt
my exhaust manfold lower center and lower left HOLES are stripped.. im running turbo so i dont think its gonna gold the pressure.. i have a tap and die set but how am i gonna fix it ? make the holes bigger and use bigger bolts? anyone have a link to a how to for this?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_serious »</TD></TR><TR><TD CLASS="quote">my exhaust manfold lower center and lower left HOLES are stripped.. im running turbo so i dont think its gonna gold the pressure.. i have a tap and die set but how am i gonna fix it ? make the holes bigger and use bigger bolts? anyone have a link to a how to for this?</TD></TR></TABLE>
You want to know how to use a tap and die set? why do you have one if you don't know how to work it?
you just put the one that will fit in the hole on there and you twist that bitch around. and then you find a bolt with matching thread patterns and then bolt in on.
im wondering if thats what other ppl have done, or drill it out and use a helicoil thing? i've only fixed like studs for valve cover for it and **** never a hole
Flux
Nov 20, 2006 06:55 AM
