How hard is it to replace the valve spring?
Old Jan 14, 2004 | 09:01 AM
RedGSR's Avatar
Default How hard is it to replace the valve spring?
I was just looking at the helms, it looks like I have to take the head off. Is that right?
Old Jan 14, 2004 | 09:21 AM
Mikizzle's Avatar
thats the only way to work internally in your motor
Old Jan 14, 2004 | 09:56 AM
P1mpSlap's Avatar
you can do it without taking the head off. It's a bit trickier that way.
You have to get a very long peice of moderatly thick string and shuve it down the spark plug hole and set the piston at TDC for cylinder that has the string in it. That way the valves do not drop.
Then use an overhead cam valve spring compressor to compress and remove the valvesprings.
Installation is the reverse as removal.
Old Jan 14, 2004 | 10:02 AM
Jasper_db1's Avatar
Default Re: (P1mpSlap)
Isn't there a method that uses air pressure (assuming your cylinder isn't leaking) to keep the valves up?
Old Jan 14, 2004 | 10:05 AM
P1mpSlap's Avatar
Default Re: (Jasper_db1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't there a method that uses air pressure (assuming your cylinder isn't leaking) to keep the valves up?</TD></TR></TABLE>
yes, I totally forget the process, though.
socialistic
22
Jul 28, 2011 01:32 PM
averyvm
Oct 23, 2006 05:35 PM
todbld
Oct 21, 2005 05:17 AM
Layziebtnh055
May 7, 2004 07:29 AM
Steve91
Sep 19, 2003 11:53 AM
