hondata or vtec controller ??
Old Oct 15, 2005 | 01:52 AM
hlee5363's Avatar
Default hondata or vtec controller ??
hey guys ... i do not knoe much about cars so im just tring to figure out what to get next... i have a 98 gsr... and yea im thinking baout putting a vtec controller... but someone recently told me who has a vtec controller told me not to get it... and he told me to get hondata... can you guy explain to me what hondata does... and what the difference is between hondata and vtec controller ??? i also want to knoe that whtas gonna be better for my gsr..... i tried doing some research on it... but found nothing.... and i was trying to research hondata but they have all these different ones... can u guys explain to me what s100 or s200 and etc... i dunno anythign.... and if your gonna tell me to research... please read again the top again... because like i said. i TRIED... thanks guys
Old Oct 15, 2005 | 02:16 AM
.water's Avatar
Default Re: hondata or vtec controller ?? (hlee5363)
from what i heard,
no gain with VTEC control
gain with HoNdAdAtA
Old Oct 15, 2005 | 02:39 AM
hlee5363's Avatar
thanks anything else ?????????????
Old Oct 15, 2005 | 04:49 AM
Ichigo's Avatar
go here http://hondata.com/
Old Oct 15, 2005 | 05:14 AM
gsrvtec2's Avatar
Default Re: (R34lude)
hondata
Old Oct 15, 2005 | 05:46 AM
BlackLudeSi's Avatar
Default Re: (tekneshum)
A vtec controller will simply let you change the point where vtec engages. Hondata is a engine management unit much muhc better. Hondata
Old Oct 15, 2005 | 07:44 AM
CNSK's Avatar
hondata s100 is fine if your cheap....s200 just the same as the 100 but comes with a few luxary items and cost a bit more.....vtec controller
Old Oct 16, 2005 | 01:46 AM
hlee5363's Avatar
what do u mean little more options.. or luxary stuff.... cause yea i heard about hondata... and i am very interested in it.. but i dunno which one to get..........
Old Oct 16, 2005 | 07:03 AM
CNSK's Avatar
Old Oct 16, 2005 | 07:11 AM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hlee5363 &raquo;</TD></TR><TR><TD CLASS="quote">what do u mean little more options.. or luxary stuff.... cause yea i heard about hondata... and i am very interested in it.. but i dunno which one to get..........</TD></TR></TABLE>
s100: you get this
s100 system - - speed limiter removed (if applicable), tunable fuel and ignition tables, expanded rpm fuel & ignition tables, VTEC control, adjustable rev limiter and Nitrous Control.
with the s200, you get full throttle shift, launch control, shift light, etc....on top of whats included in the s100. Thats why I said if your on a budget, you can just buy the s100 becuase the programs are the most important and its same as s200 model. After that, the other stuff isnt necessary but always good to have..
read up on
hondata.com
Honestly its also depends on your mods also. If you car is stock with no internal, I always suggest running your basic bolt ons, such as, I/H/E, manifold, stronger clutch, ignition sparks, and then work on getting cams, sprockets, valves springs, retainers......once your car is modified a little more aggresive that is when you want to run a obd1 ecu with hondata. The whole point of running a hondata is for tuning capabilities. If your pretty much stock, whats there to tune right? Remeber also, you need to go dyno tune your car to get your maximum HP and Tq. If you run hondata on a stock motor with basic bolt ons, dyno, and program your hondata, youll probaly see a few hp but say if you want to upgrade heavier itmes later down the road, you need to reprogram your hondata again becuase the old set up is made specifically for your old set up. Thats why its always best to get most of your mechanical items first and then run electrical items for tuning....
Old Oct 16, 2005 | 10:29 AM
EKB18C97's Avatar
what kind of vtec controller are you trying to buy? VAFCII has tuning and vtec control. Hondata is a great system no doubt.
Old Oct 16, 2005 | 11:34 AM
apok's Avatar
Default Re: (EKB18C97)
Use Uberdata, because you can tune your own car with a reprogrammable chip and the system is free minus parts to modify your ECU.
VAFC or the likes only allow minimal engine management modifications. Its nice for on-the-go modifications in a lightly tuned car, but if you want your car to run perfectly, buy a little dyno time and a wideband O2 sensor and go to town with fuel maps.
Old Oct 21, 2005 | 09:08 AM
CRXJIM's Avatar
You definatley want hondata. With the your yr car the hondata you will need to purchase will let you datalog your base runs so you can see where ur losing power.
Old Oct 21, 2005 | 09:16 AM
RagingAngel's Avatar
Default Re: hondata or vtec controller ?? (CRXJIM)
run crome.
or you can wait for Neptune....
you should begin by telling us what you have on your car.... it might not even need any sort of engine management at this point.
http://www.pgmfi.org is a good start too.
Old Oct 21, 2005 | 09:21 AM
projectTeG's Avatar
what do you have done to your car where you need hondata?
domsb16
Oct 2, 2007 03:38 PM
specialedition
May 19, 2005 12:11 AM
allmotorGs-r
Nov 25, 2004 12:27 AM
highboostb18c1
Oct 4, 2004 07:35 AM
S-fiend
Jun 29, 2004 02:54 AM
