hoe much power?
Old Nov 24, 2003 | 03:28 PM
riceball777's Avatar
Default hoe much power?
as some of your know i blew my b16 last month
https://honda-tech.com/zerothread?id=656494
and i'm in the process of compleating my ls vtec build
i know all you people hate these kinds of threds asking how much power hte engine might have but i just want a rough estamate of what kind of hp and torque i should be geting
all machine work was done by rs machines in los angeles/ carlson
b16 head,port polish head ctr cams, port flow ti retainers, rs machine duel valve springs (should be good for any cams) , and match port stock b16 intake mainfold arp head bolts
3" short ram intake . hks hyper piping, magna flow muffler, 4-2-1 dc ss header (2" collector )
arp rod bolts, polish crank and balanced whole rotating assembly, itr oil cooler
act prolight fly wheel (8.8 pounds)
b18a block, .25 over pr3 pistons (11.4cr) itr oil pump, ls rods, gsr rod bearings, everything was changes in the engine meaning all the
sensors all the houses all the belts, bearings everything with oem honda parts
oh yeah and a chiped pr3 obd 0 ecu vtec @ 4,800
so how much power can i be expecting to get untuned
Old Nov 24, 2003 | 09:11 PM
DC4 teg's Avatar
Default Re: hoe much power? (riceball777)
I'm not exactly sure but the engine is gunna have some *****! I saw what happened to ur old engine BTW. Valves give Pistons a 'high-five' I'm not a genius, but that motor is gunna haul some serious BOOTY I'm jealous Let me know how much it will put out. Get that put on the dyno and let me know man. Seems like a sweet set-up. Good-Luck!
Old Nov 25, 2003 | 12:25 AM
Ramocheese's Avatar
You can't ask how much power you'll get.. especially untuned.
Set yourself a goal. Figure out what it will take to reach that goal. Honestly, all motor hondas do not make power at all. Since hondas do not make very good torque, all power is made in revs. I don't have enough experience with all motor mods on hondas to estimate power though. I am not thinking any more than 200hp to the wheels though.
Old Nov 25, 2003 | 04:35 AM
LODOSS's Avatar
Default Re: hoe much power? (Ramocheese)
hoe much
dan's integra
Jan 7, 2007 02:43 PM
riceball777
Feb 17, 2004 05:50 AM
S13 slide
Sep 25, 2002 02:14 PM
