Highest revving integra?
Old Nov 23, 2005 | 10:35 AM
oilguzzler's Avatar
Default Highest revving integra?
Whats the highest revving integra you've seen? I know 8k(8.2k actually) is even crazy but ive seen some going north to 10k! I was just wondering because i wouldnt mind a couple extra rpms on my gsr. I know i would have to modify the ecu and install a new valve train with various other things but yea.
Modified by oilguzzler at 11:57 AM 11/23/2005
Old Nov 23, 2005 | 10:55 AM
Kendall's Avatar
I think Steve Sakai pulled one up to 12,500 once.
Old Nov 23, 2005 | 11:44 AM
DA-nteg's Avatar
Default Re: (Kendall)
shot peened rods... and upgraded valve train.. i use to pull mine to 9 all the time.. 9500 was rev limiter
Old Nov 23, 2005 | 11:47 AM
iH8RICERZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">I think Steve Sakai pulled one up to 12,500 once.</TD></TR></TABLE>
Is that the same guy who posted a video of him revving that high w/ the AC on as well!? This was a few years back when I seen it in the ITR forums.
Old Nov 23, 2005 | 11:51 AM
blakezilla06's Avatar
Default Re: (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">
Is that the same guy who posted a video of him revving that high w/ the AC on as well!? This was a few years back when I seen it in the ITR forums.</TD></TR></TABLE>
Yes, I do believe that was Steve Sakai...But I thought it was in the integra forum not the itr .
Old Nov 23, 2005 | 01:29 PM
Johnny_Rocket's Avatar
Default Re: (.::aNtI-rIcE::.)
anyone have the link to this video?
Old Nov 23, 2005 | 06:08 PM
GSR_96814's Avatar
Default Re: (JohnnyH)
My friends seen 10K every day. Not a spoon motor too. Motor still hasnt blown out even after a year
Old Nov 23, 2005 | 08:09 PM
Dartanian's Avatar
Default Re: (GSR_96814)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_96814 &raquo;</TD></TR><TR><TD CLASS="quote">My friends seen 10K every day. Not a spoon motor too. Motor still hasnt blown out even after a year</TD></TR></TABLE>
Still not a good idea. Unless it makes power that high and is reinforced for the extreme stress that those extra revs put on the bottom end, there is no reason at all to rev that high except for bragging rights.
Old Nov 23, 2005 | 08:54 PM
GSR_96814's Avatar
Default Re: (Das Schmoo)
Agreed. Hes one of those run um hard type of folks. Personally I like to baby my engine never rev past 5K unless the occasional race
Old Nov 23, 2005 | 09:25 PM
patmcd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">Still not a good idea. Unless it makes power that high and is reinforced for the extreme stress that those extra revs put on the bottom end, there is no reason at all to rev that high except for bragging rights.</TD></TR></TABLE>
And I bet there aren't many people on here with a motor built for that and still making power that high.
Old Nov 23, 2005 | 09:35 PM
jakeiscool's Avatar
Banned
Default Re: Highest revving integra? (oilguzzler)
b16supertuner had an em1 with an R motor and he revved it to 10800?? Stock bottom end.
Old Nov 23, 2005 | 09:42 PM
99SlammedCivic's Avatar
Snipper Snapper
i rev my motor to 9300 and my AVCR showed that i once hit 9983 rpms ( i dont think thats true.. maybe a glitch bc my rev limiter is 9400)..
fully built motor
Old Nov 24, 2005 | 08:20 AM
morocco's Avatar
Default Re: (99SlammedCivic)
My friend hit 9500 in his Civic Si (B18C drop) but even though it can rev that high and is awsome to watch, it doesnt mean it actually makes power at that rpm. Unless your engine is built for higher compression and higher rpms than it would be stock, Id say leave it alone. You will actually lose power at higher rpm, it really makes no sense to do that unless your engine is built to provide power at higher than stock rpms. The powerband shows that the initial cam cuts power at about 5g, and vtec kicks in until just under 8400. Since the vtec cam cuts out under its redline, it means that there is no power being made above where the redline normally is. Check out dynos on this stuff, you will find that its better (and probably safer) to leave it at the redline and do some internal work rather than letting it rev till it blows. Long response, but unless you are building your engine to rev that high (which would be cool) then its a bad idea to do it otherwise.
Old Nov 24, 2005 | 08:36 AM
projectTeG's Avatar
i saw a video of rockets turbo teg went to like maybe 11 or 12k....it was at like 6'o'clock on the tach.
Old Nov 24, 2005 | 08:59 AM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyH &raquo;</TD></TR><TR><TD CLASS="quote">anyone have the link to this video?</TD></TR></TABLE>
Old Nov 24, 2005 | 09:00 AM
Kod Sol's Avatar
Default Re: (projectTeG)
i was talking to one of my friends, and he said with an LS/Vtec swap you can get to 10,500 rpms with a b16 crankshaft. I don't think you can get much power at that rpm, but yea its probably just for bragging rights. but hey, more power to you if you can.
Old Nov 24, 2005 | 09:23 AM
silver j's Avatar
^^ seems like a pretty high piston speed don't you think?
Old Nov 24, 2005 | 09:40 AM
97tegGS's Avatar
10500RPM=175 Revolutions Per Second
Old Nov 24, 2005 | 10:21 AM
teggytegteg's Avatar
Default Re: (97tegGS)
contact OPAK RACING, they can tune your stock b16 block to make power at 10k...stock cams....im still wondering if id like to spend my money for that...
but seriously though, unless you are a circuit track *****, spinning your motor that high is just for bragging rights....
Old Nov 24, 2005 | 11:36 AM
jakeiscool's Avatar
Banned
Default Re: (teggytegteg)
high revving motors are rice
Old Nov 24, 2005 | 12:30 PM
shutupnsk8's Avatar
BANNED
spoon civc type r revs to 15k and still makes power there
Old Nov 24, 2005 | 01:16 PM
jakeiscool's Avatar
Banned
Default Re: Highest revving integra? (shutupnsk8)
huh....im pretty sure a civic is not an integra.
Old Nov 24, 2005 | 02:06 PM
Default Re: (JakeIsCool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool &raquo;</TD></TR><TR><TD CLASS="quote">high revving motors are rice </TD></TR></TABLE>
is that how you feel about the rotory and motorcycles?
Old Nov 24, 2005 | 02:21 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutupnsk8 &raquo;</TD></TR><TR><TD CLASS="quote">spoon civc type r revs to 15k and still makes power there</TD></TR></TABLE>
were did you get this from?
Old Nov 24, 2005 | 03:03 PM
oilguzzler's Avatar
Default Re: Highest revving integra? (projectTeG)
15k? thats nuts. Yea i know if i were to raise my redline i would make sure it was worth it and get it tuned for that. I also just love the scream(but hate the pounding the engine gets) with high rpms, exspecially with open headers lol. I grew up riding two stroke dirt bikes(own a 2000 cr125 right now and tops out at 13500rpms) so maybe thats where i get it from.
