Highest comp on 93pump
Subscribe
Jun 14, 2010 | 04:55 PM
I'm about to start a rebuild on my 00 gsr. I was thinking of running p73 itr pistons and a spoon headgasket as well arp rod bolts and head studs. Is this safe for a dd on 93 pump. also what cams and header would you run with this setup.
thanks in advance
Eddie
Reply 0
Jun 14, 2010 | 05:09 PM
Re: Highest comp on 93pump
Quote: I'm about to start a rebuild on my 00 gsr. I was thinking of running p73 itr pistons and a spoon headgasket as well arp rod bolts and head studs. Is this safe for a dd on 93 pump. also what cams and header would you run with this setup.
thanks in advance
Eddie
Quote: Let me know what you think of my future allmotor build plans. I've got a few questions regarding a few parts.
B20 block bored to 84.5
srp 11.5:1 pistons
stock rods with arp rod bolts
arp headstuds
GSR head with ITR springs and ti retainers
skunk2 pro1 cams
aem pully kit
lightened flywheel
skunk2 pro series intake manifold
65mm edelbrock throtle body
Q's
Will stock rods be alright for an 8200 rpm redline with arp rod bolts.
will whis be streteable
what size injectors will I need.
does anyone have a b20 shortblock for sale.
Thanks for all your help
Eddie
which one is it man??? you gonna actually respond to this one?
Reply 0
Jun 14, 2010 | 05:26 PM
idk yet I'm still playing around with ideas
Reply 0
Jun 14, 2010 | 05:29 PM
so you end up getting the gsr block, itr crank, or the b20 yet?
Reply 0
Jun 15, 2010 | 04:30 AM
ive got a gsr block right now but im burning a lot of oil so its either rebuild the gsr of fina a cheap b20 to build but i cant find a b20 block thats bare for cheap. i also read some bad things about high revs on a b20 and i love to rev my motor so im starting to think just rebuild the gsr. idk im at a crossroads right now as ive always been a turbo guy and i am still thinking of boosting it bud i just dont know yet as this is my dd.
Reply 0
Jun 18, 2010 | 02:37 PM
any one with advice is appreciated
Reply 0
Jun 18, 2010 | 07:38 PM
with forged pistons and reworked chambers you can get up to 12:1 on 93 octane and run a normal timing curve. cast pistons and stock chambers probably 11:5-1. when you hear of guys going over this and saying "get a tune" that equates to "pulling timing" which makes the engine less efficient. mpg normally suffers.
you could run itr pistons on your p72 head with an oem head gasket and be just fine. i would cc everything to check where compression actually comes out. if it starts getting high from having anything shaved you can free up a cc or two by blending your chambers and unshrouding the valve face with cartridge rolls and a die grinder
Reply 0
Subscribe
