high idle
Old Aug 4, 2005 | 03:23 AM
EJ20's Avatar
Default high idle
I just swapped a gsr motor into a 00 gsr body...everything works good except forgot to plug in the spedometer =P theres some cel's...and for some reason it idles at 1.5k ?!
why does it idle so high? did i miss a plug? ...i didnt connect a few things such as the charcoal canister...and some electrical plugs dont match up...(jdm b18c 93 motor)
Old Aug 4, 2005 | 04:22 AM
rkrone's Avatar
Default Re: high idle (EJ20)
check for vaccum leak
Old Aug 4, 2005 | 09:02 AM
OwnsAnAcura's Avatar
mess with the distributor, advance it or retard it... that shud do it
Old Sep 19, 2005 | 12:07 AM
Calvinator's Avatar
Default Re: high idle (OwnsAnAcura)
did you ever find out the problem? Im having the same problem.
Old Sep 19, 2005 | 12:10 AM
White GSR '01's Avatar
Default Re: high idle (xtremeazian)
I swapped my intake manifold for a SK2 and I have the same problem. My CEL is on because if the Inlet air temp sensor and the idle speed sensor
Old Sep 27, 2005 | 05:10 PM
FROSTDC2's Avatar
Default Re: high idle (White GSR '01)
u should get a chip to manage vtec better with that single stage manifold
97ej6dx
Dec 30, 2010 11:37 AM
julianbc2
May 12, 2009 01:33 PM
Ilove theDA
Sep 28, 2006 10:07 AM
InfamousRS
Jul 31, 2002 12:14 PM
ZColeon
Nov 16, 2001 09:02 AM
