hi-flow cat...
Subscribe
May 12, 2004 | 11:25 AM
i was wonderig if a hi flow cat from a gsr would fit and ls from the same gen. i thought it would, but im still unsure...anyone?
Reply 0
May 12, 2004 | 11:48 AM
Re: hi-flow cat... (allshowallgo)
If you're talking about G3 Integras, it will only fit a '00-'01 GS-R without modification.
Reply 0
May 12, 2004 | 01:37 PM
Re: hi-flow cat... (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">If you're talking about G3 Integras, it will only fit a '00-'01 GS-R without modification. </TD></TR></TABLE>
True Story.
Reply 0
May 12, 2004 | 03:13 PM
Yeah, but what header and exhaust was on the GS-R? Doesn't matter what car it came off of, as long as it's the right length you need and has the right number of O2 bungs.
So find out what you need and if it's what you need.
Reply 0
May 17, 2004 | 07:34 AM
Re: hi-flow cat... (96dc2)
basically, my problem is this...i have a '96 LS integra turbo and i am thinkin about runnin a high flow cat, but most of the ones made for an LS that i found are 2.25" diameter. i want something bigger, so i was just wondering which cat might fit thats a little larger?
Reply 0
May 17, 2004 | 07:38 AM
Just get a catco cat
Reply 0
May 17, 2004 | 08:49 AM
Re: hi-flow cat..
what is a good brand for a high flow cat?
Reply 0
May 17, 2004 | 08:40 PM
1994-1999 GS-R have a 17.5" cat with 2 O2 sensor bungs. Measure the cat you have on there right now and see if it matches. You may need to plug 1 or both of the bungs. Running OBD1 - plug both, your primary O2 is located in the A-pipe. Running OBD2 - plug the one upstream of the cat, install your secondary O2 downstream of the cat.
A M18X1.5 screw will work, I found a M18x1.5 oil drain plug at the auto store that worked.
Reply 0
May 17, 2004 | 08:41 PM
1994-1999 GS-R have a 17.5" cat (flange to flange) with 2 O2 sensor bungs. Measure the cat you have on there right now and see if it matches. You may need to plug 1 or both of the bungs. Running OBD1 - plug both, your primary O2 is located in the A-pipe. Running OBD2 - plug the one upstream of the cat, install your secondary O2 downstream of the cat.
Reply 0
May 17, 2004 | 11:05 PM
Re: hi-flow cat... (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">1994-1999 GS-R have a 17.5" cat (flange to flange) with 2 O2 sensor bungs. Measure the cat you have on there right now and see if it matches. You may need to plug 1 or both of the bungs. Running OBD1 - plug both, your primary O2 is located in the A-pipe. Running OBD2 - plug the one upstream of the cat, install your secondary O2 downstream of the cat.
not true. 94-95 GSRs have 1 o2 sensor while 96+ have 2
Reply 0
May 18, 2004 | 05:48 AM
Re: hi-flow cat... (Sack Master)
whats the diameter of a catco cat?
Reply 0
May 18, 2004 | 07:38 AM
they come in different sizes..check ebay!
Reply 0
May 18, 2004 | 02:16 PM
Re: hi-flow cat... (TrayDay2K1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrayDay2K1 &raquo;</TD></TR><TR><TD CLASS="quote">
not true. 94-95 GSRs have 1 o2 sensor while 96+ have 2</TD></TR></TABLE>
I stand corrected.
Reply 0
Subscribe
