Hesitation
Old May 10, 2002 | 07:46 AM
Thasty's Avatar
Default Hesitation
Every time I put it in second it will hesitate for a split second and then rev fine afterwards. I just put in a new cap and rotor and new bosch platinum 2 spark plugs which I didnt torque down I just made it tight. I made sure to watch the firing order when putting it back together. They seem fine and the plug wires are on tight. I haven't had a chance to check on it because im at work... just tryin to get some ideas so when i get home I can fix it quick.
[Modified by OnlyNod, 11:47 AM 5/10/2002]
Old May 10, 2002 | 07:47 AM
StyleTEG's Avatar
Default Re: Hesitation (OnlyNod)
Have you run a bottle of fuel injector cleaner recently? Would be worth a try.
Also it could be a clogged fuel filter.
You say this happened right after you changed your plugs? I would double check the gap and get a torque wrench to get them at the right spot, they might not be far down enough in the cylinders.
[Modified by StyleTEG, 4:48 PM 5/10/2002]
Old May 10, 2002 | 07:48 AM
protocol_droid's Avatar
Change the plug wires? Had a similar problem on my 95 GSR, it sputtered/hesitated then would go. I changed the wires and problem was solved.
Old May 10, 2002 | 08:23 AM
Thasty's Avatar
Default Re: Hesitation (protocol_droid)
Yes it happened right after I changed all this crap. The plugs are pre gapped and im going to torque them down tonight, usually hand tight is good buy i guess not in these cars. As for the wires, Im going to be changing them today also.
egGSR_hi
May 16, 2009 12:23 PM
milanocivic
Feb 20, 2009 08:26 PM
Faultless18
Dec 9, 2008 01:56 PM
zcmotor
Apr 30, 2008 02:17 PM
cyr0ch
Jul 29, 2004 04:58 AM
