help with trouble code
alright so I found out what it is, but it's mostly on civic, not integra and no definite answer to where this is, can anyone point me in the right direction on how to fix this problem?
Check out this thread...a guy had a similar problem and ended up replacing the distributor...could be the solution.
http://www.hondacarforum.com/honda-3...ode-p1362.html
-What kind of exhaust manifold?
-What size injectors?
I guess if you're only planning to make 250HP it will be a pretty basic/minimal set-up...
Let me know if you need any help figuring out what you're going to buy to turbo it...I can help you piece together a kit.
http://cgi.ebay.com/ebaymotors/3-5-b...Q5fAccessories
-Note: Ebay is good for minor things such as piping...I recommend getting a good brand name Turbo, Wastegate, BOV, Injectors (DSM 440CC Injectors are good for basic/minimal set-ups)...for everything else, e-bay should be alright (for a basic/minimal set-up).
You want one that exits off the passenger side, right?...doesn't this do that?
http://cgi.ebay.com/ebaymotors/integ...Q5fAccessories
Rosati
Acura TL, RL & ZDX
Jan 4, 2008 07:32 AM
