::help:: mph guage question....
Old Aug 23, 2003 | 08:13 PM
..::91TEG-G2::..'s Avatar
Default ::help:: mph guage question....
i have a 91 teg, and when i drive, and the needle goes between 20mph to 35mph, it bounces up and down... then when i go above 35mph, it stops and goes smoothly up.. what could be causing this to shake? and is there a way to fix it?
Old Aug 23, 2003 | 10:29 PM
mr.beeks's Avatar
Default Re: ::help:: mph guage question.... (..::91TEG-G2::..)
check the speedometer cable it might be jamming
Old Aug 24, 2003 | 04:28 AM
808style's Avatar
Default Re: ::help:: mph guage question.... (francisco flores)
probably need to grease your speedo cable. common problem on DAs from what i've been reading.
Old Aug 24, 2003 | 04:02 PM
TEXN3's Avatar
Default Re: ::help:: mph guage question.... (808style)
its more of a common problem on any older cable speedometer, regardless of the car type. the grease hardens and the cable doesn't operate as well. the cable itself is pretty cheap from honda/acura, but the labor isn't as fun. there is a DIY guide on http://www.g2ic.com go to "teg tips" and then scroll through the "interior" section.
i would recommend joining the forum also, it will be an alternative asset to helping you with any problems on your g2 integra.
Old Aug 24, 2003 | 05:05 PM
DA-MAX's Avatar
Default Re: ::help:: mph guage question.... (texnteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texnteg &raquo;</TD></TR><TR><TD CLASS="quote">but the labor isn't as fun.</TD></TR></TABLE>
"isn't as fun" is an understatement, its hell...
the devil created speedo cables on the G2
Old Aug 30, 2003 | 05:53 AM
808style's Avatar
Default Re: ::help:: mph guage question.... (DA-MAX)
is it really that bad? i was plannin on replacing mine tomorrow. you guys got me scared now...
Old Aug 30, 2003 | 07:37 AM
mr.beeks's Avatar
well the instructions on g2ic are not that helpfull
but yeap you have to laying on your back looking up into the dash in order to
route the cable.
Old Aug 30, 2003 | 09:02 AM
DA-MAX's Avatar
its not hard, but its just tedious...and prepare to get your hands scratched up when connecting the cable to the back speedo cluster, that was annoying as well
joonguyen
Mar 17, 2008 10:56 PM
schuetts
Jun 6, 2006 10:05 PM
redDAinteg
May 25, 2005 09:05 AM
Snail Tuning
Jan 17, 2003 04:53 AM
