Help with LSv swap
So i did whats needed to do the lsv swap enlarged the dowel holes in HG and put dowels where there suppose to be, plugged up the oil hole and redid the line knock sensor etc, it runs no idleling no CEl's problem is. when im in neutral and in gear one i release clutch and go, problem is theres no power as in it lags until about 45 to 5 when vtec hits then its like turbo! so pretty much no power between 1-45 rpm plus motor gets super hot but doesn't over heat.
engine b18b
head pr3
p30 manifold
70mm skunk2 tb unnessary i know
ebay 4-1 head straight to obx 2.5 piping/exhaust
p72 ecu
some help would be appreciated
engine b18b
head pr3
p30 manifold
p72 ecu
Make sure your timing is done properly. As for getting hot, did you run the oil line correctly into the back of the head? Also, what type of setup did you use for the oil routing? Sandwhich plate? or what?
It may sound stupid, but make sure you arent leaking coolant anywhere.
i didnt use the sandwich i just ran it into the back of the block as the same as the head oil line. not leaking any fuilds, the first time we started it up it was really bad, oil pressure light keep coming on. WE flushed oil and coolant out and opened up the oil pan, there was lots i mean lots of metal shavings we cleaned it up and the pressure light went away now its just laging 1-45. in for more help :D
Also, i used to have an LS/vtec, i didnt build it, but i maintained it a great deal. Correct me if im wrong, but isnt there TWO oil lines that need to be ran?
just the block to head, the metal shaving where from the block and head when first started up? im geussing it clogged up the oil line to vtec. that was why the pressure light kept coming on.
Also, redo the timing.
Also, just to note: The p72 ECU will run like **** with a pr3 head/ manifold setup. It will lag pretty bad until VTEC. Also, if you had a lot of oil shavings in the engine you should plan on rebuilding/ scrapping the engine.
egzo04
Dec 19, 2006 12:42 AM
bagg248
Apr 21, 2004 07:12 PM
Kasper.
11
Aug 28, 2002 07:48 AM
