Help with lighting/wiring
Old Mar 6, 2011 | 03:52 AM
Squigget's Avatar
Default Help with lighting/wiring
So I recently bought a 1995 GS-R.. but i noticed the interior lighting for my heater buttons sometimes want to work and sometimes don't. But now my left blinker just wants to stay on when i turn my lights on. it doesnt flash. it just stays on..
These are cell phone quality so sorry if its bad...
I have a pic of what it looks like when my lights are on:
http://i25.photobucket.com/albums/c8...0305112300.jpg
and a video of when my lights are off and i hit the blinker switch down:
http://s25.photobucket.com/albums/c8...0305112310.mp4
anything to help me would be greaatt. Thanks
Old Mar 6, 2011 | 06:50 AM
lazlong's Avatar
Default Re: Help with lighting/wiring
You have a short in the combination switch or the wire(s) leading to it. Check for a loose connector then check the wires.
Old Mar 6, 2011 | 09:17 AM
Squigget's Avatar
I'll check it out today after i wash her. Thank you
Old Mar 6, 2011 | 09:59 AM
fcm's Avatar
fcm
Old Fart
I would check dash harness grounds.
If the left signal light, [blinker] only stays on when park/head lights are on check the tail light ground and tail/signal light dual filament bulbs, you can unplug the tail lights and if problem goes away the problem is in the tail lights.
Question, when the left signal light indicator, [in cluster] is on, are the front and rear left signal lights on, including left front side marker, and again is it only on when park/head lights are on? 94
Old Mar 6, 2011 | 10:19 AM
Squigget's Avatar
When i turn the parking lights on the signal stays on to. The front signals light up too but they don't flash. I am missing two bulbs on each side on my front corners. There's supposed to be 2 bulbs in each unit. i bought the car with the side bulbs broken because there is water in the unit, so i need to order new corners. they working fine for a week..
From the back it stays lit up with my tail lights. When i turn on my headlights theres no difference. But when all lights are off and i use the left turn signal my dash lights flash with it along with my tail lights just like in the video
Old Mar 6, 2011 | 11:27 AM
mark@silbernage's Avatar
Also check every fuse. Strange things happen sometimes when the power starts to take alternate paths through circuits that share a common ground. It can seem like you have a poltergeist.
Old Mar 6, 2011 | 09:59 PM
Squigget's Avatar
I think i figured it out. I went to put new corners on and the bulb thats in there was being weird. When i would lock it into place is when it wouldnt flash at all. im going try buying new bulbs
Dennis Basille
Honda Civic (2006 - 2015)
Jan 29, 2016 11:21 AM
TrackRat
Jul 19, 2010 01:23 PM
skullbiz
Jan 27, 2010 03:52 PM
wilaivue
Dec 1, 2008 06:20 PM
estillme
Mar 12, 2004 11:08 AM
