Help with horrible alignment
Old Dec 26, 2024 | 07:21 PM
oli333's Avatar
Default Help with horrible alignment
97 RS 2 door 5spd
I replaced front upper control arms, ball joints, inner/outer tie rods
next on the list is front LCA, compliance arm and bushing, end links, tein flex, rear control arms and sway bar
Before I go spending all that time and money, does this front caster look like frame damage or just bent arms?
Also, will an aftermarket adjustable rear toe kit fix the rear toe or is a rear arm bent? Passenger side rear is maxed out going positive
Old Dec 27, 2024 | 04:11 PM
oli333's Avatar
Default Re: Help with horrible alignment
To add, the driver’s side of the core support does appear to be welded by a previous owner but the strut mount appears straight on both sides
Old Jan 9, 2025 | 06:23 AM
3rdtimecharmer's Avatar
10 Year Member
any pictures of the car? might help
Old Jan 9, 2025 | 09:46 AM
gutted-dx's Avatar
Im dealing somwhat the same problem. 97 Civic and I need a camber kit to get everything in the green but only on one side. Has all orignal panels and no crash history.
2stroke1971
Dec 10, 2023 11:06 AM
Farlander
Mar 2, 2011 05:13 PM
davidluko
Suspension & Brakes
Mar 30, 2009 05:47 PM
chaserz
Honda Civic (2001 - 2005)
13
Jul 24, 2008 10:57 AM
mingbling96
May 30, 2006 01:18 PM
