HELP!! FUEL INJECTION!!!!
heres wats going on:
-CEL #16 (fuel injection)
-FPR is okay holds 40psi, and when vacum hose disconnected rises up
-fuel pump obviously is working because its providing the pressure and fuel
-fuel injectors were checked for resistance and within specs
-fuel injectors work because they are all clickin
-fuel injector work obviously because injectors are clickin
what i do notice is that the check engine light after i reset the computer comes on before i turn the car on right when the fuel pum finishes priming it turns on so when i turn on the ignition normaly the light comes up and then goes away well it comes on then when the fuel pump finsihes pumping the light goes away for like a second and comes back on.....idk if that means anything
i need honda-tec.com's help please
Modified by maxboost_50psi at 9:14 PM 2/22/2007
jshireaz
12
May 22, 2010 05:29 AM
2oh6civic
Mar 30, 2003 07:26 AM
