Help, Clutch Problems!!
Old May 12, 2007 | 01:12 PM
The Flying Dutchmen's Avatar
Default Help, Clutch Problems!!
I've been having some problems with my 2000 GS. I was driving home the other day and it suddenely became really hard to shift. Barely got it back, first thing i checked was the fluid. It was low so I refilled it but the problem persisted. After I drive for a bit the engagement point sinks to the floor and i can't get it into gear when it's moving. Sometimes when i'm sitting still in gear with the clutch fully depresses the idle is rough and the car wants to move forward.
I have bled the system multiple times. I changed the slave cylinder and rebled the system as well. I am still having the problem. I have done plenty of searching and for most if this did not solve the problem, it was something with the clutch spring or the whole clutch had to be replaced. I do have ~130k, and the original clutch as far as I know.
How do I know if my clutch spring is not in the right place? Where should it go? I cannot find a good DIY for changing the clutch. Can anyone help with a link?? I have done it one my 96 civic, but with help from a friend.
Thanx for any help
Old May 12, 2007 | 02:34 PM
Exeed's Avatar
Default Re: Help, Clutch Problems!! (The Flying Dutchmen)
http://www.team-integra.net/se...D=957
that's about as detailed an article as you're going to find. I hope it helps.
Old May 12, 2007 | 06:20 PM
anyone else?
alexsneesby
Aug 18, 2010 12:11 PM
OG SHG_EM1
Oct 30, 2007 07:50 AM
hatchsi0485
Nov 21, 2005 06:13 AM
onyx00
Dec 11, 2004 02:56 PM
alfaaay
Mar 31, 2003 11:57 AM
