help with abs light!
Read this thread: https://honda-tech.com/zerothread?id=978933
Pull the code and see what your problem is.
Could be just dirt on your ABS sensors. take them out, clean them (carb cleaner or brake cleaner does a good job) and see if the light goes out. Also check that there's fluid in the ABS reservior...good luck
newhondaowner29
Jan 11, 2006 08:11 PM
