Help !!!!!!!!
I have a 1994 Acura Integra LS 4dr sedan
OK so where did you connect the PCV Valve ??? My problem is I bought a car from someone and was told they changed the head. After I got the car home I noticed it burned alot of gas for an Integra so I started doing some research and started checking my hose's and I notices the PCV Valve has no where to go I got a Hose sticking out the IM that has a PCV valve on it but it just hangs there's no Black Box in the back I don't feel the littel Nipple for the Hose in the Back near the Oil Filter and I only have one hole in the valve cover and it connects to the air filter I tried to swap the hose's and Oil started shooting out of the corner ?? I can't figure out where to plug it ?? Man any advice would be much apprecieted !!! I will name my next kid after the person who can help me save my car ???
that hose your talking about should connect to the pcv valve...atleast i believe it should i have had many honda b-series engine and ik what black box your talking about on the back of the motor...i do believe that newer ls motors do not have this box on the back but dont quote me on that...hope i helped in some way for you
OK but my block does not have the black box and my valve cover does not have a hole for a PCV valve how can I fix can I add the black box I think I have a 94 block and a 96 head with a 94 valve cover what can I do to fix this ??
obd1 block have the pcv canisister on the back of the block which is where the pcv valve is.
obd2 blocks dont have the pcv canisister (the hole on the block is not there for the canisister to go into) and the pcv valve is on top of the valve cover and the vaccumm line goes to the top of the intake manifold.
it sounds like you have and obd2 engine, so to make the pcv valve work the way its intended to you will need to get the valve cover that has the hole in it where the pcv valve goes.
you def need to be running a pcv valve too so fix it asap
amej8
Apr 10, 2011 05:35 PM
pg_thao
May 21, 2002 03:52 PM
