heim endlink help
Old May 27, 2004 | 09:40 PM
oMek's Avatar
Default heim endlink help
today i installed some heim type endlinks on my gsr, im using the 22mm itr swaybar. when i installed them i jacked the car up and them jacked the tire up so it was like the car was sittin on the ground. the endlinks dont move very much at all and im wondering if this is gona cause sub frame tearout? should i install them again with the wheel hanging down more so there is more slack in them?
Old May 28, 2004 | 09:23 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: heim endlink help (oMekoneDC2)
I doubt the endlinks would cause the swaybar mounts to tear out of the subframe. Just make sure the bar is mounted directly to the subframe w/ a mount kit, and NOT on the stock Integra swaybar brackets.
I assume you jacked up both wheels when installing, correct? Otherwise you would have had to twist the swaybar and I don't think you did that.
Old May 28, 2004 | 09:42 AM
oMek's Avatar
Default Re: heim endlink help (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I doubt the endlinks would cause the swaybar mounts to tear out of the subframe. Just make sure the bar is mounted directly to the subframe w/ a mount kit, and NOT on the stock Integra swaybar brackets.
I assume you jacked up both wheels when installing, correct? Otherwise you would have had to twist the swaybar and I don't think you did that. </TD></TR></TABLE>
yes both wheels where jacked up even. wow i forgot how much diffrence a ite swaybar makes
MeanstreakCivic
10
Mar 13, 2008 10:30 AM
wifesaynogo
Suspension & Brakes
Feb 4, 2007 01:19 PM
FkingSUV
21
Jan 3, 2005 07:48 AM
turbotime
22
Aug 10, 2004 08:46 AM
NightRiderS2K
Jun 3, 2003 10:18 PM
