Heater Core ... HELP!
Old Feb 4, 2008 | 04:28 PM
tweee's Avatar
Default Heater Core ... HELP!
Okie dokie ... where do I even begin ... 1st time i replaced the heater core because it was leaking inside my car (passenger side) ... had to replace it a 2nd time because the heater core that I bought the first time was a defect and it still leaked and i got some kind of smoke coming from the vents inside the car ... okay here is my problem now ... my windows are easily fogged up and when the vents are open it smells like coolant BUT there is NO leak ... is it still the heater core or is there something else I should be looking for?
94 LS Integra
Old Feb 4, 2008 | 04:49 PM
t0ekn3e's Avatar
up so tweee gets helped
JFG Kevin's Avatar
Default Re: Heater Core ... HELP! (tweee)
Change your cabin filter if you have one if not spray some lysol (however you spell it) in the vents from out the the car...let it sit a little bit and see if the small goes away...
Old Feb 4, 2008 | 04:51 PM
tweee's Avatar
Default Re: Heater Core ... HELP! (JFG Kevin)
What is a cabin filter?
Old Feb 4, 2008 | 04:55 PM
JFG Kevin's Avatar
honestly...i dont know if Integra or Civic have them...but it's a filter that is after teh blower to filter out dust...
all-mtr-teg's Avatar
Make sure you don't have another leak, otherwise it may just be the left over coolant from the defective heater cores still evaporating. I had the same scenerio about a week after I replaced my heater core, so one day I just took my portable heater set it inside the car on a metal pan and turned it on low and let it evaporate all the coolant. Took about 4 hours.
Old Feb 4, 2008 | 04:57 PM
tweee's Avatar
Default Re: Heater Core ... HELP! (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you don't have another leak, otherwise it may just be the left over coolant from the defective heater cores still evaporating. I had the same scenerio about a week after I replaced my heater core, so one day I just took my portable heater set it inside the car on a metal pan and turned it on low and let it evaporate all the coolant. Took about 4 hours.</TD></TR></TABLE>
i checked to see if the leak was there but no leak ... floormats and carpet are dry ... looked up and still no leak ... popped hood to have a look see ... and see nothing ... the thing is it's been a couple of months i believe shouldn't it evaporate by now?
Old Feb 4, 2008 | 05:03 PM
Yeah the water may have evaporated but the actual chemicals in the coolant "ethylene glycol and other stuff" is probably still in the carpet, so try some febreez or carpet upholstry cleaner to get that out, if not, some car auto detailers can steam clean and shampo it for pretty cheap.
Old Feb 4, 2008 | 05:05 PM
importdude2000's Avatar
make sure your windshield crowl isnt leaking either
those rubber washers rip over time
Old Feb 4, 2008 | 06:39 PM
tweee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the water may have evaporated but the actual chemicals in the coolant "ethylene glycol and other stuff" is probably still in the carpet, so try some febreez or carpet upholstry cleaner to get that out, if not, some car auto detailers can steam clean and shampo it for pretty cheap.</TD></TR></TABLE>
no ... its not in the carpet ... you can only smell the coolant when the vents are open ... after the heater core was replaced the second time i took out the seats and shampooed them already ... a week later i took my seats out again and steamed them ... floor mats were put in afterwards ... im thinking that there's a leak or moisture somewhere internally because the windows fog up so easily ... i dunnoe what it is ...
Old Feb 4, 2008 | 08:06 PM
lilsaigon510's Avatar
wash my car and i tell u the secret to solve the problem
Old Feb 4, 2008 | 08:31 PM
ThaLost0ne's Avatar
Default Re: Heater Core ... HELP! (lilsaigon510)
haha
Old Feb 5, 2008 | 02:03 PM
OUT OF ORDER ROB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilsaigon510 &raquo;</TD></TR><TR><TD CLASS="quote">wash my car and i tell u the secret to solve the problem </TD></TR></TABLE>
Wash my Cars But Naked and ill fix it fo you
Old Feb 5, 2008 | 04:15 PM
tweee's Avatar
Default Re: Heater Core ... HELP! (OUT OF ORDER ROB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OUT OF ORDER ROB &raquo;</TD></TR><TR><TD CLASS="quote">
Wash my Cars But Naked and ill fix it fo you </TD></TR></TABLE>
you guys are so mean!!
AWD Terror's Avatar
Coolant will not evaporate. If it did, you would have to fill it up every time you drove your car.
The only way to get the coolant out of your carpet is to take it out, shampoo and vacuum it. It will need to be done many times.
Keep an eye on your coolant level to be sure that you do not have a leak still. You may have bent the leads going to the heater core when you were installing it. Also make sure your hoses are 100% on the core. If the leak is internal, you should be able to see the coolant on the bottom of the heater core box.
Old Feb 5, 2008 | 04:22 PM
tweee's Avatar
Default Re: Heater Core ... HELP! (AWD Terror)
there's no leaks on carpet or floormats ... no smell ONLY when heater is on or vents are open ... so ... i basically would have to remove everything to get to the heater core to check the hoses for leaks of some sort?
Old Feb 5, 2008 | 04:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweee &raquo;</TD></TR><TR><TD CLASS="quote">
you guys are so mean!!</TD></TR></TABLE>
Okay you dont gotta wash my car but you Can shake yo *** fo me but naked and ill fix the heater core problem
Old Feb 5, 2008 | 04:29 PM
tweee's Avatar
LOL
Old Feb 5, 2008 | 04:30 PM
Haha. But yeah my Cousin Car has the same smell but then again he did accident shoot his dash in the pilot So Coolant Was everywhere
Old Feb 5, 2008 | 04:32 PM
tweee's Avatar
Default Re: (OUT OF ORDER ROB)
wth? ahha i have no leaks OUTOFORDERROB?!
Old Feb 5, 2008 | 04:34 PM
Maybe from b4 just not all the way Dry out yet.?
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweee &raquo;</TD></TR><TR><TD CLASS="quote">there's no leaks on carpet or floormats ... no smell ONLY when heater is on or vents are open ... so ... i basically would have to remove everything to get to the heater core to check the hoses for leaks of some sort?
I would check from under the hood first. You could have a pin hole leak spraying right into the cabin.
Anothing thing to do is to take off the cover for the heater core. It's very simple to do with everything in place. With the cover off, rev the engine and have someone lay under the dash and look for leaks.
I would not take the heater core back out just b/c of a smell, but that's just me. You could also have a leak under your hood somewhere and the blower is just sucking up the fumes into the cabin.
Old Feb 5, 2008 | 04:35 PM
ls19integra95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OUT OF ORDER ROB &raquo;</TD></TR><TR><TD CLASS="quote">Haha. But yeah my Cousin Car has the same smell but then again he did accident shoot his dash in the pilot So Coolant Was everywhere</TD></TR></TABLE> ROFL, thats sucks though
but to the op, i recently had my heater core blow and i changed it and it took me almost a month to get the smell of coolent out... inside your heater core houseing there is foam on the flaps, they could have soaked up the chemicals and be releasing the small when you turn your heat on and it blows warm air over them, also you could just have the smell up in your vents from the chemicals also... so like some said already, spray some lysol or somethin like that into your vents and let it dry... im betting the chemicals just dried into the foam inside your hc houseing and is why your air smells when you turn the heat or somethin on...
Old Feb 5, 2008 | 04:40 PM
tweee's Avatar
AWD Terror and ls19integra95 thanks ... will try to do ... but i dunnoe i really think there's still a leak somewhere or something because the windows fog up so easily and it wont defrost with the a/c ... windows will fog due to moisture right?
Old Feb 5, 2008 | 04:46 PM
mine still fog up real easily too and will only unfog when i put the defroster on with the heat cranked... but watch your coolent level and see if your radiators slowly loosing coolent and thats one way of telling if your still leaking... but as AWD said, it could be in engine bay and your vents are just sucking the smell up... thats actually why i kept smelling coolent for a month, found out my radiator cap was bad and leaking coolent out of it and it was just coming through my vents.
