heater core :(
Old Sep 2, 2004 | 05:46 PM
R.S.'s Avatar
Default heater core :(
I well i was drivin home from my dad's (15 min ride, where i was workin on the car).
The engine over heated, coolant was low and i eventually saw that for sum reson i removed one of the hoses that goes to the heater core(on the fire wall) when i put it back on i kindof bent/ crushed it a tiny bit(like before it was a circle and now it's a oval).
I found coolant inside my car on the floor.
I refilled the radiator w/ coolant and havent drivin it since, i still need to do sum other things to it.
could i have fucked up the heater core by doing this or could i just shape the metal pipe that the hose connects to (on the firewall) back to a circle and put the hose back on and be all good?
Old Sep 2, 2004 | 07:25 PM
R.S.'s Avatar
Default Re: heater core :( (R-Spec)
i did a lil searching and looks like i can just bend it back to shape and fix it up then put the hose back on, this shoudl work correct?
also any one know the best way to clean the coolant from the carpet? let it dry? i do have a vacum that washes carpets (w/ water and soap), should i use that?
Old Sep 3, 2004 | 04:03 AM
speedymon's Avatar
Yeah just shampoo your carpet really good and don't lick it.
Old Sep 3, 2004 | 03:44 PM
R.S.'s Avatar
gona try this tomarow...
Modified by R-Spec at 4:53 PM 9/4/2004
Old Sep 4, 2004 | 12:55 PM
R.S.'s Avatar
well i fixed the copper hose pretty good, and put some honda bond then pout the hose on w/ a new/better clamp...can't drive it yet tho (waitin on header and exhaust)
hopefully this worked...
zx92027xz
19
Jan 15, 2014 04:36 AM
schueytenten
Jan 7, 2014 01:24 PM
LGxGirL
Nov 26, 2012 10:58 AM
Paprika
Dec 21, 2004 04:51 AM
