heat?
Old Oct 16, 2005 | 03:19 PM
skata89's Avatar
Default heat?
do you have to have ac to have heat? and how do i get my heat to work?
Old Oct 16, 2005 | 03:25 PM
nitrofish420's Avatar
Default Re: heat? (skata89)
No, working A/C isn't necessary for heat. What's the symptoms?
Old Oct 16, 2005 | 03:31 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Re: heat? (nitrofish420)
Wierd coincidence. Like If I don't have AC on and no air on at all (set to off) and say the temperature setting part is on hot, super hot air will still come through all of the vents, and when it is on cooler portion, cool air from outside comes in, I don't really get it.
Old Oct 16, 2005 | 03:34 PM
94eGsr's Avatar
make sure all you heater hoses are connected,
or that your blend door is not stuck
Old Oct 16, 2005 | 04:56 PM
skata89's Avatar
were is the heating unit located?
Old Oct 16, 2005 | 05:00 PM
Default Re: heat? (Bat Country)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bat Country &raquo;</TD></TR><TR><TD CLASS="quote">Wierd coincidence. Like If I don't have AC on and no air on at all (set to off) and say the temperature setting part is on hot, super hot air will still come through all of the vents, and when it is on cooler portion, cool air from outside comes in, I don't really get it.</TD></TR></TABLE>
If you set it on recirculate that'll stop. It's just from the draft of outside air coming through the heater core and out your vents. When you click on recirculate it blocks off the outside air inlet and flow stops.
Benjamin Allan
Honda Civic (2006 - 2015)
Jul 3, 2018 05:43 AM
devilpuppy
Aug 15, 2008 04:02 PM
TedR719
Jun 7, 2004 11:58 AM
Transport
Apr 21, 2004 12:38 PM
Prevail
Jun 22, 2003 06:33 PM
