Header situation!!!!
Old Sep 30, 2006 | 04:49 AM
MyFirstTuner's Avatar
Default Header situation!!!!
Ok im ready to start again i got a 93 integra ls 1.8 b18a obd1 engine can i use the header from my 1991 ???? this car already runs stronger than my 91 ls so im so happy with this new[IMG][/IMG] one im going to add a pic of it as i start keep a running log
Old Sep 30, 2006 | 07:21 AM
purplegsr's Avatar
Default Re: Header situation!!!! (MyFirstTuner)
If you do use the header from your 91, you will have to reroute your o2 sensor wire so that it doesn't come out close to the collector/cat, but comes out so it will plug into the left most runner on your 91 header. That's the main difference between the 2, I think they are the same length. However, you might want to look on g2ic or elsewhere on H-T, because I think that the cat changed length between 90-91 and 92-93, that is why most 90-93 exhaust systems came with an adapter so you could use them on the 92-93 models.
Old Sep 30, 2006 | 11:24 AM
90da r's Avatar
92-93 converters are longer can't use 90-91 header.
Old Sep 30, 2006 | 11:32 AM
purplegsr's Avatar
Default Re: Header situation!!!! (90da r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90da r &raquo;</TD></TR><TR><TD CLASS="quote">92-93 converters are longer can't use 90-91 header.</TD></TR></TABLE>
I checked into this, and this is correct.
This thread might help as well:
http://www.g2ic.com/forums/sho...ength
Old Sep 30, 2006 | 04:02 PM
Default Re: Header situation!!!! (purplegsr)
so not even custom fitment on install i have an aftermarket hi flow for 90-93 so it says
boomersz
May 3, 2007 12:45 PM
DA_JDM
Mar 6, 2007 08:49 AM
jweezy225
Jun 18, 2006 05:34 PM
bliss@5200
Apr 7, 2006 10:42 PM
civickiller
Nov 25, 2005 10:53 AM
