Which header for DA?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm420da6 »</TD></TR><TR><TD CLASS="quote">for starters...jdm 4-1 headers wont fit...so leave that out of the question....unless u cut the front x-member...
Which isn't that big of a deal.... He'll probably run into this problem with any 4-1 header.
I have a Honda jdm 98 ITR header on my DA and I love it.
There are quite a few choices, depending on your budget.
I ran a cheap Airmass 4-2-1 header and made 197whp on my built n/a motor a few years back. A 4-2-1 will give better mid range power/torque where as a 4-1 will do best up top. If your car is mainly a daily driver I would go 4-2-1.
If your going hard core you could always go Hytech or even SMSP, which are considered the best in the business. I'll warn you ahead of time though they are damn $$$$$ as they are custom fabricated for you.
My opinion go for something like a Comptech header. Check them out, im sure they make a header for your DA.
Goodluck.
Goodluck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 »</TD></TR><TR><TD CLASS="quote">
true..true..just wasnt something id get into....i had a DC 4-1 but didnt want to have to do that....but i guess its still an open option for him
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OldGSR »</TD></TR><TR><TD CLASS="quote">I have a dc 4-2-1 ceramic which i'm very satisfied with</TD></TR></TABLE>
Ditto
Ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE bEe GuY »</TD></TR><TR><TD CLASS="quote">
Ditto
iam getting that next ..
currently have a megan racing one..
ss
it kicks *** for 120!
but i gotta get dc for carb
CA EMISSIONS Is CRAP
cops ask for carb now...you dont have em
say hello to ref
Ditto
ss
say hello to ref
Ill be running a Vibrant JPSEC 4-2-1 with the 2.5'' collector on my DA. Its an exact replica of the T1R/JUN header, but it does require you to notch the cross-member pretty good. Its supposed to give very, very good power, and looking at it in person- Im very satisfied with the quality. Its beefy.
Ground clearance (a big issue on DA's) is supposed to be awesome.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout289 »</TD></TR><TR><TD CLASS="quote">anyone have any smog-legal [CA] suggestions for DA? [meaning other than DC].</TD></TR></TABLE>
Here is my list from when I was deciding, I ended up going with a new DC 4-2-1 ceramic with the nice little welded on plate. If I had any of these I would carry around the EO print out with me.
Lightspeed CARB EO D-377-4
Part #s H02625, H02652B, H03028
Airmass CARB EO D-465
Part # 80000, 80057 (90-91 DA)
Part # ,80002 80502 (92-93 DA)
Edelbrock TES Shorty EO D-215-52
Part 6629, 6729, and 6829
Chikara (made by Hedman) EO D-167-16
Part # 36010, 36014 for 90-91
Part # 36020, 36024 for 92-93
ZR Racing EO D-532
08-AC-01 for 90-91
08-AC-02 for 92-93
I left the DC one off, since you didn't ask for that.
If you want to look up the correct part # and get a short description, just type the EO number in this search form:
http://www.arb.ca.gov/msprog/a...y.php
ZR Racing EO D-532
08-AC-01 for 90-91
08-AC-02 for 92-93
I am running a DC 4-2-1 ceramic also. But, the clearance issue with a 4-1 is nothing if you have one of these:
I can run any damn header I want now!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstock93 »</TD></TR><TR><TD CLASS="quote">Ill be running a Vibrant JPSEC 4-2-1 with the 2.5'' collector on my DA. Its an exact replica of the T1R/JUN header, but it does require you to notch the cross-member pretty good. Its supposed to give very, very good power, and looking at it in person- Im very satisfied with the quality. Its beefy.
Ground clearance (a big issue on DA's) is supposed to be awesome.</TD></TR></TABLE>
Were exactly can u get this header and how much does it cost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaseIntegra »</TD></TR><TR><TD CLASS="quote">I am running a DC 4-2-1 ceramic also. But, the clearance issue with a 4-1 is nothing if you have one of these:
I can run any damn header I want now! </TD></TR></TABLE>
Nice is that Full Race crossmember and traction bars? Hows the install... direct bolt up?
i just ordered my full-race traction bars today. . . can you still use the factory radiator tabs??? or do you have to chop them for the install? I'm still using the normal size radiator. . .
Quit showing off.
I'm jealous. I want one of those so badly.
As a side note, my jdm itr 4-1 DOES NOT hang very low at all on my DA. Ground clearance is great, IMO, considering the design of the header.
Quit showing off.
Yeah they are Full-Race! I love them soo much. You don't have to do any modifications to install it. It bolts to the front mount, and the frame and it's all direct bolt on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChaseIntegra »</TD></TR><TR><TD CLASS="quote">Yeah they are Full-Race! I love them soo much. You don't have to do any modifications to install it. It bolts to the front mount, and the frame and it's all direct bolt on.</TD></TR></TABLE>
that might help my issue...I hit a big rock and bent the $%*&$ out of my crossmember and it tweaked the radiator. how do you mount the bottom of the radiator with the? and how much of a PITA is it to remove the x-member?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout289 »</TD></TR><TR><TD CLASS="quote">that might help my issue...I hit a big rock and bent the $%*&$ out of my crossmember and it tweaked the radiator. how do you mount the bottom of the radiator with the? and how much of a PITA is it to remove the x-member?</TD></TR></TABLE>
That sucks
That sucks
POE
20
Jan 30, 2004 11:15 AM
