Head Bolt Torque specs.
Old Feb 12, 2003 | 06:14 PM
Four Door LS VTEC's Avatar
Default Head Bolt Torque specs.
Can anyone provide me with the correct torque specs for the head bolts?
Isn't there a tightening sequence that i should follow also?
thanks.
Old Feb 13, 2003 | 07:01 AM
Default Re: Head Bolt Torque specs. (Four Door LS VTEC)
help? .....please?
planning on putting motor back together this weekend
Old Feb 13, 2003 | 09:47 AM
shamoo's Avatar
Will you make something up for me please?
For stock head bolts....
(8.7 kgf.m, 63 ft-lbs) Apply motor oil to all threads first and top of washer.
Tighten them in this sequence. Imagine looking at motor from front of car. And reading bolts from left to right starting from intake side:
8, 4, 2, 6, 10 <---intake order
7, 3, 1, 5, 9 <---exhaust order
Hope that helped dude.
Torque them to 22ft-lbs first in that order. Then to 63ft-lbs in that order.
Good luck.
Old Feb 13, 2003 | 02:26 PM
Default Re: Head Bolt Torque specs. (shamoo)
thanks to INVTEC for the pm.
shamoo is right. almost. close enough. First you torque to 22 and then to 60. close enough. thanks a lot.
Old Feb 13, 2003 | 05:08 PM
shamoo's Avatar
Hey, I'm reading right out of the Acura shop manual from the dealer. It's got more stuff than the Helms.
Old Feb 13, 2003 | 05:13 PM
ok your right.
UserX826
Sep 5, 2008 06:40 PM
EG93si
Dec 30, 2005 06:16 PM
g1zcteg
Oct 26, 2005 11:21 AM
NOOTRON20
Oct 11, 2003 10:18 AM
