Hatch Stuck, Shut
Old Jun 26, 2005 | 12:42 PM
Ls InTeGrA RaCeR's Avatar
Default Hatch Stuck, Shut
My hatch is stuck shut on my Teg. It would do this every now and then and then it'd come unlocked after playing with the latch a little. Anyone have any clues how to get this thing unstuck?
Old Jun 26, 2005 | 01:11 PM
Cliffjumper2's Avatar
Default Re: Hatch Stuck, Shut (Ls InTeGrA RaCeR)
You probably have a bent hatch opener cable or hatch latch.
carefully remove the rear panel and check your latch to see if it's bent, also carefully remove the opener cover (right by your driver door shared with the gas lid release) and check for any damage there.
if thsoe two places seem to be ok, then you have to remove your driver side plastic panels and check the route of the cable to the rear to see if there is anything kinking it or if it's damaged.
the helms manual has the full layouts if you can get your hands on one of those...but it's self explanatory once you find the cable.
gl
Old Jun 26, 2005 | 01:13 PM
Default Re: Hatch Stuck, Shut (Cliffjumper2)
I have a 99ls bro....no latch on the inside of the car. My latch is on the hatch (great design idea POS)
Old Jun 26, 2005 | 01:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR &raquo;</TD></TR><TR><TD CLASS="quote">I have a 99ls bro....no latch on the inside of the car. My latch is on the hatch (great design idea POS)</TD></TR></TABLE>
ok, still need to check your latch/release/cable where ever is located...there most likely is something bent or kinked.
Have you examined these things already?
Old Jun 26, 2005 | 01:24 PM
yeah, but how would these things get bent? they're tucked behind the interior framing of the car.
Old Jun 26, 2005 | 01:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR &raquo;</TD></TR><TR><TD CLASS="quote">yeah, but how would these things get bent? they're tucked behind the interior framing of the car.</TD></TR></TABLE>
this is why I said to check the ends first (the release lever and the latch)
as for how....**** happens man...people install dynamat/stereos/remove plastic panels and put them back on and as for the latch and lever getting bent, that can be done many ways...attempted theft through the hatch, someone messing around with the release lever.......a lot of ways.
not saying it's the cable itself, but if you've checked everything else (and it's fine), then you need to check the cable itself to make sure it hasn't been moved to make it get kinked.
journeyquest
Sep 3, 2010 02:47 PM
rattlecannedEF
Jan 19, 2009 10:49 AM
blumpfish
May 30, 2006 11:27 AM
iperez
Mar 28, 2006 12:10 PM
rasinhell
Jan 13, 2005 12:48 AM
