harness question
Old May 4, 2009 | 04:20 PM
cristegra09's Avatar
Default harness question
i recently have a 95 integra with no engine harness..i was offered a 94 engine harness jus wanted to know if it wuld match me car? and i have a engine that came out of a 95-96 not sure...and i need to know if the 94 harness wuld b no good to run that engine?? 8324928384 anybody can hit me up i need to know asap..thanx
Old May 4, 2009 | 04:44 PM
mouab18c1's Avatar
Default Re: harness question
if your motor is 94-95 then you need an obd1 harness. 96-97 are obd2a 98-01 are obd2b..so im assuming you have an obd1 motor in your car unless swapped out then the 94 harness should work for it.
Old May 4, 2009 | 06:17 PM
well see i bought the engine from a junkyard and i dnt know if the car they got it from was from a 95 or 96.. idk wat kinda harness it had wit it ,but it was a 4door thats all i know.. i do have the p75 ecu i jus needed to know if the 94obd1 harness will go rt wit the 96 engine i have
Old May 4, 2009 | 06:43 PM
mouab18c1's Avatar
so your motor is a 96? if it is then no the 94 harness will not work. you need a 96-97 harness. obd1 harness has two plugs for the distributor. all obd2 only have one plug
Old May 4, 2009 | 08:08 PM
o ok. when i seen the engine turn on in the other car the distrebutor had 1 plug.. that mean its a obd2 rt?? and when i droped the engine n my car the distrebutor harness of my car needed has 2 plugs.. i tried switching the connections from the distrebutor from 1 plug to 2 plugs since they both had same color codes. but now i know i need a obd2 harness to make it run rt n switch bak the harness's from the distrebutor..
D_koschak
Mar 20, 2012 11:01 PM
JJGL-EF90
Nov 26, 2010 10:30 PM
avaldez
21
Jun 24, 2009 09:15 AM
pine_apple45
Apr 25, 2007 07:02 PM
ShowtimesDC2
Sep 7, 2003 05:53 PM
