gutted hatch
Old Mar 3, 2002 | 08:49 PM
SleepinGSR's Avatar
Default gutted hatch
THis is the best Pic I could get
Old Mar 3, 2002 | 09:43 PM
Hapa DC5's Avatar
Default Re: gutted hatch (cyb3r sn1p3r)
now scrape that tar off...
Old Mar 3, 2002 | 09:56 PM
nerdish's Avatar
Default Re: gutted hatch (NemesisGSR)
And what's the best way to scrape the tar off?
Old Mar 4, 2002 | 12:40 AM
dlric's Avatar
Default Re: gutted hatch (nerdish)
i think dry ice seems to be the most preferrable way to do it. get a big block of it, then break it up and spread it on the tar. i've heard of mixing it with some kind of alcohol solution (i think) to make it easier. you can then just bang on it lightly with whatever tool u can find and it will break into pieces. i also used a mini propane torch and just melted that stuff. i used a plastic putty knife to scrape the melted tar up. problem with this method is it is not the most efficient way as it leaves black tar residue that is a pain in the **** to get off. dry ice and cold weather
Old Mar 4, 2002 | 06:46 AM
Big Teggie's Avatar
Default Re: gutted hatch (dlric)
I got all the tar out my trunk, but not the rest fo the car, and its getting warmer and harder to take off. Where can i get dry ice at? thanks
Old Mar 4, 2002 | 07:33 AM
SMSP's Avatar
Default Re: gutted hatch (Big Teggie)
Usually a welding supply house
Old Mar 4, 2002 | 08:03 AM
Big Teggie's Avatar
Default Re: gutted hatch (SMSP)
thanks dave, is it expensive?
Old Mar 4, 2002 | 10:26 AM
stevel's Avatar
Get a fire extinguisher (or some tank) and have it filled with CO2. It freezes to
-110 degrees (probably Celsius). That should be enough. That's what a friend of mine did. Then just take a screwdriver and hammer and pound at it. He said it just comes off in sheets.
s
[Modified by stevel, 2:27 PM 3/4/2002]
Old Mar 4, 2002 | 11:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: gutted hatch (stevel)
Be sure to wear gloves when handling dry ice, it can freeze burn your skin if you handle it w/ bare hands.
litterbox
Aug 22, 2005 08:41 AM
sleevedgsr
Dec 13, 2004 03:43 PM
GReddy SI
13
Dec 10, 2002 11:04 PM
94LSTEG
Feb 26, 2002 05:27 PM
r30slick
Jan 26, 2002 08:45 PM
