gsr throttle cable problem
i recently swapped out the gsr manifold for a skunk2 one. I got the honda ITR throttle cable and bracket, got it hooked up. i used a throttle pulley of a da ls integra.
now my PROBLEM is, that the cap where the throttle cable goes into the firewall doesnt wanna go in all the way(kinda lose) also for some reason the throttle will get stuck sometime and make my car sound like it has a vaccum problem. and if my car is running and i move the cable under the hood the idle goes way high. if i pull up on my gas pedal the idle will go back down. The idle is at about 1100 rpms and i adjusted the idle screw on the TB
PLEASE HELP
PLEASE HELP
I have just about the same problem. More than likely the throttle cable is kinked somewhere, so you might have to replace it. Mine just snapped on me today on the highway. Man!!! Hope you got it fixed!
bk7794
13
Jun 21, 2012 08:17 PM
