GSR shifting problem
Old Oct 10, 2005 | 06:24 PM
xrdriver's Avatar
Default GSR shifting problem
I have a 95 GSR engine/tranny in a 93 Civic Si Hatch. It has been running mint for about 16 months but last night I developed a problem.
I am experiencing a problem where I cannot shift into 2nd or 4th. It's like the shifter just won't go into those gears. It happens if I try and downshift or if I am driving 'nice.' If I give 'er and get up in the revs I can upshift into 2nd and 4th just fine. If this happens and I coast to a stop I cannot get into these gears until I accelerate in first and then shift. I have tried double clutching to bring the tranny up to speed but no go.
I recently installed a turbo on the car so I am leaning towards a bad clutch but I find it hard to believe it would only affect those 2 gears.
I have a no name short shifter, but shifting has been smooth as butter for 16 months.
Any help would be appreciated.
Old Oct 10, 2005 | 06:48 PM
I B Z's Avatar
Default Re: GSR shifting problem (xrdriver)
could be syncros
Old Oct 10, 2005 | 07:07 PM
xrdriver's Avatar
Default Re: GSR shifting problem (TangkenBoo2)
It COULD be...but it is not that shifting is difficult - it is impossible! It does not grind, it is completely locked out.
Old Oct 10, 2005 | 08:15 PM
gsrobdi's Avatar
does it go in a pop back out?
Old Oct 10, 2005 | 08:33 PM
xrdriver's Avatar
Default Re: GSR shifting problem (gsrobdi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrobdi &raquo;</TD></TR><TR><TD CLASS="quote">does it go in a pop back out? </TD></TR></TABLE>
Nope - it's like the shifter forks are jammed. I just tested it and found that it won't go in reverse when it is locked. I just had to push it out of a parking spot
Old Oct 10, 2005 | 08:48 PM
AlphaQup's Avatar
Seems like its time for a new tranny. LSD y0!
Old Oct 10, 2005 | 09:48 PM
xrdriver's Avatar
Default Re: GSR shifting problem (AlphaQup)
I installed an ITR LSD last year....jdm y0
Old Oct 10, 2005 | 10:39 PM
AlphaQup's Avatar
lol y0!
Old Oct 11, 2005 | 09:01 AM
xrdriver's Avatar
I will be changing the fluid and shifter tomorrow to see if that helps.
Old Oct 12, 2005 | 01:31 PM
xrdriver's Avatar
I drained the fluid and filled the tranny with Synchromesh today and it almost feels a little better but I am still getting times where 2nd and 4th are locked out. It does not grind into the gears - they are completely locked out.
Old Oct 12, 2005 | 01:36 PM
AlphaQup's Avatar
When was your last Clutch change?
Old Oct 12, 2005 | 03:21 PM
xrdriver's Avatar
Yeah....I am thinking about that too. The clutch came with my swap so I have no idea how many miles are on there other than the 12,000 I have put on it
I was going to change the clutch this winter because I put the turbo on recently and it sometimes slips It is not a big deal to me if it is the clutch.
I am going to see if I can get it to lock up while the car is off. I figure if it locks only when the car is running then it HAS to be the clutch.
90datech
Transmission & Drivetrain
22
Dec 15, 2012 06:40 PM
kanaboy
Oct 12, 2009 11:04 PM
freshrex4g
Oct 25, 2004 05:47 PM
ChillOutWayne
Jul 31, 2004 10:35 PM
AznInvasion
Jun 19, 2003 12:35 PM
