gsr question
Old Dec 5, 2008 | 10:51 AM
lcsej1's Avatar
Default gsr question
hey guys! one of my camshaft holder was broken, i had one laying around from my old gsr so i swapped them. It directly touches the camshaft. Its the last holder besides the vtec solenoid. my teacher said that i should have done that because the wear patter is different in everyengine. he told me that i have two options, either get a new head or take it to a machine shop to the the camshaft assembly balanced! what do you guys think?
Old Dec 5, 2008 | 11:14 AM
slaminsam's Avatar
Your teacher is right to some extent. Every engine does have a different wear pattern. The caps for the cams do not have any cam bearings so the best idea would be to take the cam out and mic the inside of the cap with it torqued down to see if it is out of round and compare it to the others. I have heard of people swapping them out with no problems but I myself have not done it. It could cause excessive wear if it is out of round. I really dont think camshaft balancing would do anything. If anything the machine shop would line hone the caps.
Old Dec 5, 2008 | 11:19 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I swapped a cap once because I nicked it pretty good trying to pry it off.... I swapped it with another one I had laying around and never ran into any problems. But maybe I just got lucky.
Old Dec 5, 2008 | 11:42 AM
lcsej1's Avatar
I do believe it touches the camshaft!
the one in the circle is the one i replaced! You guys think i should proceed with the swap?
Sprint2007
Mar 22, 2010 03:00 PM
dc2much
Jan 10, 2010 06:03 PM
supaslowdx
Sep 24, 2009 08:57 AM
Kataku2K3
Feb 24, 2003 12:59 PM
frogscivic
Jan 31, 2003 12:57 AM
