GSR question....
uhhhh theres lots of stuff different.. just like there is from a 94 and a 99..
the 94-97's are most alike externally, and the 98-01's have a few things different cosmetically. For the most part, the mechanics of them are the same, but if youre going to heavily modify/turbo it, a 94 or 95 would be best since its still obd1.
Someone else should be able to help you better but I believe there is a difference in the exhaust measurements of the gsr's after 99. Something with the cat/o2 bung placement?
I'm not sure where I got that from but it's sticking in my head, someone can help you better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS_DON4500 »</TD></TR><TR><TD CLASS="quote">obd2a and obd2b</TD></TR></TABLE>
yahtzee.
yahtzee.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danza »</TD></TR><TR><TD CLASS="quote">Someone else should be able to help you better but I believe there is a difference in the exhaust measurements of the gsr's after 99. Something with the cat/o2 bung placement?
I'm not sure where I got that from but it's sticking in my head, someone can help you better</TD></TR></TABLE>
Yea, the 94-99 GSR exhaust manifold is not interchangable with other integra headers. It will bolt up to the engine, but you would have to shorten the cat to make it work.
98-01 front bumper is more aggressive looking
98-01 rear bumper has air dam
Headlights are different size
Bumper lights are different size
98-01 taillights are all red,
94-97 has amber turn signals
94-97 steering wheel says "Acura",
98-01 steering wheel has the "A" symbol
98-01 have a just a fuel lever,Styling lines were added to the side mirrors in 96. Pre-96 Integras had smooth mirrors
Side door moldings were color-matched to car’s body color in 97 for LS models and in 95 for SE models
ODB II Introduced in 1996
Keys have computer chip built-in in 2000
Exhaust system changed in 2000
96 up valve cover on LS is flat across over the cam section, 94-95 cover has raised parts over the cam section. no hatch lever
_taken from team integra
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglessb18 »</TD></TR><TR><TD CLASS="quote">is the 92 gsr obd1?></TD></TR></TABLE>
I believe it's obd0.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gen2Gen3teg »</TD></TR><TR><TD CLASS="quote">
I believe it's obd0.</TD></TR></TABLE>
Nope, 90-91 Integras are obd0, 92-95 are obd1, 96-99 are obd2a, and 00-01 are obd2b.
and 00-01 GSRs have the same exhaust dimensions as the exhaust systems on 94-01 LS/GS/RS/SE and 97-01 ITRs - they all have at least 1 o2 sensor on the header, and obd2 ones have 1 on the cat as well.
99gsrbholtz
Oct 12, 2010 09:15 PM
