gsr hub pull
You remove the 32mm axle nut and then use a slide hammer w/ a FWD axle puller from Autozone to yank the hub. It takes quite a bit of banging to completely remove the hub from the bearing since they're interference fit together.
truesleeper
Apr 14, 2005 10:58 AM
