Gsr Code 43
Old Apr 8, 2014 | 12:50 PM
nicknack25's Avatar
Default Gsr Code 43
I have a gsr swap in a crx. I've been using cheap 91 costco gas for a while and just recently put in a full tank (from close to E) of chevron 91 pump gas. Somewhere around a day later, I get a check engine light for code 43, but it drives completely normal. Vtec still hits hard. Actually runs better.
Any reason to this? Is it possible the fuel could have been contaminated? What even triggers the code? The o2 sensor? Is it possible that the chevron fuel is just cleaning up the all the old deposits which tricks the ecu or o2 into thinking there is a fuel problem?
Old Apr 8, 2014 | 01:55 PM
B_Swapped93's Avatar
Default Re: Gsr Code 43
https://honda-tech.com/forums/acura-integra-6/throwing-code-43-1990-integra-2798228/ and google around that's a hard one to diagnose the cause in my experience.
Old Apr 8, 2014 | 02:43 PM
HondaPartsHero's Avatar
Technical Hero
If you clear the code does it come back?
Old Apr 8, 2014 | 07:12 PM
nicknack25's Avatar
Originally Posted by B_Swapped93
https://honda-tech.com/forums/showthread.php?t=2798228 and google around that's a hard one to diagnose the cause in my experience.
Thanks man. That thread gave me a few ideas. I'll keep filling with chevron for a few more tanks, see if the cel keeps coming up. It's pretty random right now.
Old Apr 8, 2014 | 07:13 PM
nicknack25's Avatar
I just cleared it right now, i'll let you know if it comes back on.
Old Apr 10, 2014 | 04:17 PM
nicknack25's Avatar
Alright, a little update here. The code 43 came back last night but i wasn't able to drive with it on for that long to check the symptoms. I felt like it lost some power, but it was really hard to tell. After two hours of sitting, turned it on and the cel was hidden. Drove home normal.
I just decided to do a valve lash adjustment this morning just cause it has been a while. Also checked the spark plug gaps and they were at 1.1. I read that Gsr's gap was 1.2-1.3 so i gapped to 1.2. Turned her on and sounded much healthier. Drove around a couple blocks and it seems fine. I'll be doing some more driving though and see if it comes back.
podom
Jun 18, 2014 03:06 AM
madmax91efsi
Aug 13, 2008 10:10 PM
white90rexsi
25
Sep 2, 2007 05:16 PM
sickvtec
May 25, 2006 06:58 PM
Ratedrr
Jul 29, 2003 02:40 PM
