gas tank
Old Oct 12, 2003 | 05:08 PM
ggangtong81's Avatar
Default gas tank
my gas tank is messed up. i bought this car(95 ls) and it is giving me a hard time around these days. even if i fill up the gas, the needle doesn't go all the way to F. it only takes 11 dollars to fill up the whole tank!!! i think there is a problem with the gas tank, but not sure. i talked to the previous onwer, and he doesn't knwo why either. what is wrong with this gas tank??
RedLinin247
Guest
Posts: n/a
Default Re: gas tank (ggangtong81)
could be dented inward, causing the gas tank to be smaller. hence less gas going into it.
Old Oct 12, 2003 | 05:09 PM
Default Re: gas tank (RedLinin247)
what can i do to fix it?? if i let mechanic to do it, will it be hard to fix it?
Old Oct 12, 2003 | 06:06 PM
Calavera's Avatar
have you tried filling up in different gas stations? I had a problem like that before, I just topped it off with extra gallon or so.
Old Oct 12, 2003 | 06:21 PM
Default Re: gas tank (Calavera)
yes i did, but still samething happened. i think the car was hit in the back. bu tnot sure if it bent the gas tank, but if i fix it, would it cost a lot?
Old Oct 12, 2003 | 06:23 PM
NeoGSR's Avatar
i'd think it'd be a good idea to check regardless if it's been hit in the back......otherwise something bad could happen if you were hit again
pepsi813
Honda CR-V & Element
May 19, 2019 12:41 PM
null.
Jun 22, 2005 07:03 PM
ekdriven
Jun 8, 2004 08:39 AM
garrybloom
Apr 24, 2003 09:28 AM
