fuse keeps blowing
Old Mar 20, 2010 | 08:47 AM
rmauro's Avatar
TRIAL USER
Default fuse keeps blowing
on a '96 integra fuse 13, 7.5a when i turn the key the fuse reads 0.0 ohms. i've checked the wires and unpluged the radiator fan, condenser fan, a/c compressor, blower motor, rear defrost. it still reads 0.0 ohms when key is on but reads 25.6 ohms when key is out.
any advice would be great.
rmauro
Old Mar 20, 2010 | 11:33 AM
rmauro's Avatar
TRIAL USER
Default Re: fuse keeps blowing
this is on a '96 integra
Old Mar 20, 2010 | 11:53 AM
mrdeadman's Avatar
They let me pick
Pull the fuse and check it.
If it was blown, it would read --- Ohms.
Assuming you have a multimeter, switch to continuity and recheck.
It is the setting that look like -|<|-
Is there something that doesn't work?
If the fuse really is blown, then the causes are usually an electrical short, a frayed wire is touching the chassis.
Old Mar 20, 2010 | 01:56 PM
skipper28-DC's Avatar
^yea sounds like a you got a short somewhere
Old Mar 21, 2010 | 01:14 PM
j1219z's Avatar
try looking at the license plate ground wire maybe the water make it short
Old Mar 22, 2010 | 11:29 AM
dC5_rIcEr's Avatar
replace the fuse with a known good fuse of the same amperage rating to check if your getting the same readings
iwannarace
Nov 1, 2014 10:08 PM
Blacknight117
Mar 23, 2012 09:34 AM
demiseraph
Aug 5, 2011 05:12 PM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
ModlesSI
Feb 22, 2003 03:16 PM
