Fuse keeps blowing
Old Aug 23, 2008 | 09:38 AM
sleeperrex's Avatar
Default Fuse keeps blowing
My taillight/instrument light fuse keeps blowing. It never happened before. I took a sharp turn last night and it jus stopped working. I tried replacing it with a 10, 15, and 20 amp fuse.
When i just let my car sit there its fine, but when i start driving , the fuse just blows
What should i check?
Old Aug 23, 2008 | 11:03 AM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: Fuse keeps blowing (sleeperrex)
I would get a hold of a helms manual and check for grounds. Also check the wires to see if they are warn and shorting out.
Old Aug 23, 2008 | 11:37 AM
Dogginator's Avatar
Daisy... Daisy...
Do not use larger fuses. You run the risk of overheating the wiring and increasing the severity of your problem.
Do you own a multimeter?
Old Aug 24, 2008 | 03:07 PM
sleeperrex's Avatar
Default Re: Fuse keeps blowing (Dogginator)
I got a multimeter....where should i start ? Last night i put in a fuse and my lights worked for like 20 mins.......now they blow instantly every time i replace it.
its my tailight/cluster fuse, and its not my radio cus i disconnected the whole thing and it still happneed
Old Aug 24, 2008 | 04:12 PM
Dogginator's Avatar
Daisy... Daisy...
Unfortunately you have one of the worst electrical problems to diagnose: intermittent. Does the car have an alarm? If so, I would look at the relay that controls the parking light output first. Check for grounded hot wires.
Mishima
Jun 30, 2009 09:08 PM
ludesrv
Jun 26, 2007 08:03 AM
honda530
Aug 25, 2004 11:30 AM
tuan...
Aug 7, 2004 05:47 AM
