Funky Noise
Old Oct 5, 2003 | 08:49 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Funky Noise
My buddies gsr is making a funny noise right when he takes off...not on a normal take off but on like a NOOB driver take off where the clutch is just held in a bit longer on the take off...its coming from the intake side but he doesnt have an intake but i do know his resonator box is removed...i was thinking that it could be since his resonator box is removed but any other suggestions on what it could be...the noise sounds like the whistle from an intake filter but its a lot louder
Old Oct 5, 2003 | 10:09 PM
SubTitle's Avatar
Default Re: Funky Noise (ciRcuitSi y0!)
bump
Old Oct 6, 2003 | 06:00 AM
SubTitle's Avatar
Default Re: Funky Noise (SubTitle)
Old Oct 6, 2003 | 02:30 PM
SubTitle's Avatar
bump for honda- TECH!
Old Oct 6, 2003 | 02:31 PM
NightRiderS2K's Avatar
In-N-Out Burger
describe the noise...
Old Oct 6, 2003 | 02:35 PM
SubTitle's Avatar
Default Re: Funky Noise (NightRider-gsR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">describe the noise...
ahhh.... whswiiiiiiiiiiiiissssssssshhhhhhhh (almost like a BOV )
almost like a nosie when the brakes are going bad but i just changed the brakes ( and no its not the brakes breaking in) this noise has been going off for a while,
Old Oct 6, 2003 | 03:16 PM
b18cu's Avatar
I had a noise like that...I think I had the idle to low turned the idle back up and it went away. don't know if thats your problem but...?
Old Oct 6, 2003 | 03:22 PM
kreamy's Avatar
Default Re: Funky Noise (b18cu)
well if it also happens when you go down a gear and slowly release the clutch untill the revs match up without blipping...well that my friend is probably of one the clutch bearings....dont remember its exact name...but i believe its on the recieving side of the transmission.
Old Oct 6, 2003 | 03:27 PM
sickintegra4u2nv's Avatar
i had that prob it was a piece of plastic hangin down rubin on the tire..but i would check tranny fluid and engine oil to be on the safe side
jr408
Mar 19, 2008 09:39 AM
jesseb01x
Honda S2000
Nov 19, 2006 12:02 AM
ef_boy
Jun 10, 2006 04:11 AM
RedDC5
10
Apr 25, 2005 05:33 PM
devilpuppy
Audio / Security / Video
22
Jul 22, 2004 06:34 AM
