Fuel Filter
Old Aug 28, 2003 | 02:24 PM
B16OnTop's Avatar
Default Fuel Filter
can someone write up a description on changing the fuel filter off of a 97 LS? i did a search and didnt really get to much. my car has been sitting in the shop for 3 months and i finally get to go pick it up tomorrow so i was gonna change the oil, tranny fluid, radiator fluid, and the fuel filter. also which tranny fluid should i use? Honda MTF or GM syncromesh? one last question, how much does an OEM fuel filter cost for my car?
Old Aug 28, 2003 | 02:55 PM
zad5's Avatar
check the team-integra.net articles for the fuel filter. for the fuel filter in my opinion dont take off the battery cables dont unplug the fuel pump thing. some people take out a fuse and some people unplug the fuel pump thing. but in my opinion it doesnt matter what you do a lil fuel will come out because there will be fuel still in the fuel filter. and if you do absolutely nothing like wut i did only a lil fuel comes out nothing too crazy.so its up to u. but its pretty self explanatory jus check out the article. jus watch out for the bottom fuel line thing use a wrench that is more then a regular wrench forgot whats it called like it covers more like 3/4 of the bolt. use that so it doesnt strip the fuel line. i think its called a pipe wrench but not sure
on the tranny fluid i went with the cheaper one honda mtf. if you get gm synromesh makes sure it is the friction modified version search for a picture to see the difference.
xsi-t
May 30, 2011 05:16 PM
poodlemuffer
Feb 13, 2006 05:04 AM
