Front Lower Mounts
Old Mar 15, 2011 | 05:02 AM
lmrh92's Avatar
Icon6 Front Lower Mounts
My lower front mounts just went out, i think they are called the transaxle mounts ( correct me if im wrong), but i wanna know how easy to replace these and how to do it...is there a DIY or Article On It..?
Please help!
Old Mar 15, 2011 | 05:12 AM
Spawne32's Avatar
Default Re: Front Lower Mounts
if your talking about a 3g integra, which i will assume you are, and you are talking about the lower torque mount, which i will assume you are, then its 3 bolts, slide it off, install new one, rinse and repeat.
www.rockauto.com usually has the best prices on mounts
Old Mar 15, 2011 | 06:17 AM
lmrh92's Avatar
is it the same for the passenger side to?
Old Mar 15, 2011 | 07:21 AM
sleepydb8's Avatar
yes, 2 bolts to the frame and big bolt holding the mount to the bracket
Old Mar 15, 2011 | 08:55 AM
vrrodri's Avatar
If the mounts are bad you might want to check suspension parts like ball joints, etc although I do not know if rock auto has the best prices for those.
Old Mar 15, 2011 | 10:25 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
For ball joints I highly recommend Moog. For engine mounts I personally went with OEM Honda. The ones on Rock Auto might be fine, but generally I go with OEM Honda parts if I can.
I just bought a bunch of stuff from Rock for our 96 Corolla and it all seems fine.
Old Mar 15, 2011 | 12:24 PM
lmrh92's Avatar
Thanks Guys, does rock have a site?
and some how my bolt came out my rear motor mount can anyone tell me where i can find one?
Old Mar 15, 2011 | 05:29 PM
lmrh92's Avatar
anyone?
Old Mar 16, 2011 | 06:23 AM
Community Builder
www.rockauto.com
For bolts I would recommend an online Honda parts dealer such as www.acuraauotmotiveparts.org
Old Mar 16, 2011 | 07:19 AM
lmrh92's Avatar
https://www.hondapartsunlimited.com/...ENGINE%20MOUNT
The bolt i need is number 22, and shipping is entirely to much for a little bolt, what can you tell me the size of the bolt
Old Mar 16, 2011 | 07:33 AM
Community Builder
It's a 12mm bolt, 101mm long. The thread pitch is 12x1.25mm
Old Mar 16, 2011 | 09:43 AM
vrrodri's Avatar
I was looking at rock's website and noticed they sell the upper BJ...I thought that once was not serviceable.
Old Mar 16, 2011 | 11:13 AM
Community Builder
Yeah I've heard conflicting info on that. Not sure if it can or can't. I'm thinking it can be serviced, but Honda just doesn't sell it separately. My upper arms needed both new bushings and new ball joints so I just went ahead and got brand new complete OEM Honda upper arms.
Old Mar 16, 2011 | 03:40 PM
lmrh92's Avatar
thanks guys but lucky i did some searching and found the bolt laying next to the cv, now the only problem is getting it back in
dc_jdm_dreams
Dec 18, 2013 12:24 PM
Spawne32
Dec 20, 2010 03:50 PM
dem0nk1d
Nov 11, 2010 02:31 AM
Hyoriu
Nov 28, 2008 09:32 PM
totsie7944
Feb 5, 2008 07:29 PM
